Old 02-15-2010, 08:36 AM
erkan20069 is on a distinguished road
Exclamation Circle with hatching
I have to do a G-Code milling a circle with a simple hatching inside.
i want to change just 2 parameters --> circle diameter and hatching spacing.
please help!
Old 02-16-2010, 05:54 AM
jpg
Old 02-16-2010, 01:25 PM
Pandinus is on a distinguished road
Post
Trig. is your friend...
http://www.1728.com/circpart.htm
whenever 2 chords of a circle intersect at a point E, then AE • EB = CE • ED
if we use the diameter of the circle through the center as one chord then
let H be the hatch distance, and D the diameter, while AE=EB
AE • EB = CE • ED
AE • AE = [D+H] • [D-H]
AE = SQAREROOT( [D+H] • [D-H] )
this will get you started
Code:
(This code was tested in Mach3)
#1=10 (diameter)
#2=.5 (hatch)
#3=FIX[#1/#2]
#4=0
m98 p1 l#3
m30
o1
#5=[sqrt[#4*[#1-#4]]/2]
g0 x[#4*#2] y#5
g1 y[-1*#5]
#4=[#4+#2]
m99
Oh no I think I just made a geek of myself.
Gcode for circle Chrille86 G-Code Programing 3 04-19-2009 08:42 PM
cut circle bbrown2005 Mach Wizards, Macros, & Addons 2 02-04-2009 06:41 PM
Problem- circle AngelT Mach Mill 1 06-30-2008 08:59 AM
Circle problem Captain Midnigh Milltronics 3 11-09-2006 02:11 PM
Surface Hatching option ? Ken_Shea OneCNC 2 06-13-2003 12:28 PM
