| G-Code Programing Discuss G-code programing and problems here! |
| These X and Z values are not correct - just add your own. G0 X65.0 Z10. (Rapid to Start Position) G92 X59.5 Z-50 F2.0 (Setup cycle and 1st cut) X59.0 (2nd cut at 59mm) X58.5 (3rd cut at 58.5mm) X58.0 (4th cut at 58mm) X58.0 (5th cut at 58mm – spring cut) G00 X80 Z10; or G76P_Q_R_ G76X_Z_R_P_Q_F_ First G76 Line Info G76 P010060 Q00500 R.001 (finish Passes) G76 P010060 Q00500 R.001 (chamfer Amount At End Of Thread) G76 P010060 Q00500 R.001 (tool Tip Angle) G76 P010060 Q0050 R.001 (minimum Depth Of Cut - Radial Value) G76 P010060 Q0050 R.001 (finishing Pass Depth) Second G76 Line Info G76 Xx Z R P Q F (minor Dia Of Male)(major Dia Of Female) G76 X Zx R P Q F (end Point Z) G76 X Z Rx P Q F (radial Difference. Of Tapered Thread) G76 X Z R Px Q F (Height Of Thread - Radial Value) G76 X Z R P Qx F (First Depth Of Cut - Radial Value) G76 X Z R P Q Fx (Feedrate / Pitch) ***R Value Can Be Omitted If Cutting A Straight Thread*** We do training courses if you are interested.
__________________ The Fanuc Support Center Team www.fanuc-support.com |
| Need Help!- Thread spec for camera lens filter thread | cmays | General Metalwork Discussion | 3 | 08-22-2010 01:14 PM |
| acme thread combos and thread mixing | calaber40 | Linear and Rotary Motion | 5 | 05-15-2009 08:04 PM |
| Thread mill external NPT thread | cutting edge | General Metalwork Discussion | 11 | 09-15-2008 08:33 AM |
| Need Help!- M42 x 2 thread, first thread is sharp! Help... | Driftwood | General Metalwork Discussion | 8 | 08-24-2008 02:17 PM |
| Need Help!- M42 x 2 thread, first thread is sharp! | Driftwood | General Metal Working Machines | 5 | 07-18-2008 11:09 PM |
