Old 02-09-2010, 03:10 AM
Summer5 is on a distinguished road
Help required
Hey, i used a code a few years back when i was learning that set the z workshift in programme.
can anyone remind me of the code to use.
Fanuc system.
Thanks.
Lee
Old 02-09-2010, 04:31 AM
christinandavid's Avatar
christinandavid is on a distinguished road
Offset Work Offset
Don't know if you are refering to a Machining Centre, but if you are: -
Work Offsets are called using G54-59 or G54.1 P_ on newer Fanuc.
If you are refering to offsetting the Z in relation to compensating for current Tool Length use G43 H_ (Tool Length Offset No.)
G52 Z_ will offset the current work offset also - but you must reset this back to zero in pgm I believe.
These codes are probably the same for lathes, not sure.
DP
Old 02-09-2010, 04:50 AM
yes, im working on a lathe, i just need to set the current position of the tool as Z0.0.
i dont recognise those methords for what i did before.
thanks for the input though.
Old 02-09-2010, 05:02 AM
Setting Z Offset
You should be able to touch on a face with a tool and input that position into your work offset table, either with some kind of 'measure' key or look at the current 'machine' co-ordinate and input that figure into your work offset table.
Note that your tool length will need to be set correctly first (or you may have a 'zero length' tool you use for setting Z. Your program must call the correct work offset (G54-59 I presume).
DP
Old 02-09-2010, 11:33 AM
stevo1 is on a distinguished road
Summer,
What kind of Fanuc control are you using? This will dictate what you were probably doing in the past. If you were on the older controls that did not have G54-G59 workcoordinates then you could have been using a "workshift" or G50 setting. If you are on the later controls you could have been using the G10 function.
Are you using tool offsets as well?
Stevo
Old 02-09-2010, 04:41 PM
fanuc-support.c's Avatar
fanuc-support.c is on a distinguished road
It can be done in Macro B.
Were there any # (hash) symbols do you remember?
The Fanuc Support Center Team
www.fanuc-support.com
Old 02-10-2010, 02:53 AM
im not sure exactly what controls i was using. i set a work position on a work offset position.
ita just a code in the programme that changes the z in the work offset.
it was a simple G or M code followed by Z*.*
*.* being the new Z position you wish to change it to.
thanks again for your input.
Old 02-10-2010, 03:05 AM
Pandinus is on a distinguished road
g92 z0
Old 02-10-2010, 04:23 AM
is G92 not a threading cycle?
Old 02-10-2010, 04:50 AM
G92 on a mill is for coordinate offsets -- lathe its threading
http://www.cncezpro.com/gcodes.cfm
Help required please powely General Metalwork Discussion 7 04-05-2010 03:36 AM
help required willheg Stepper Motors and Drives 3 12-14-2009 04:41 PM
Help required kookie_guy Bridgeport and Hardinge Mills 2 05-15-2009 08:51 AM
G320/G340 'Required Direction Setup' and 'Required Direction Hold' times? margni74 Gecko Drives 2 12-05-2008 08:10 PM
PARAMETERS REQUIRED KIRAN.BHAGWAT. Want To Buy...Need help! 0 11-12-2008 05:28 AM
