| G-Code Programing Discuss G-code programing and problems here! |
I need help with threading issues... I want to make .485-18 un-2a thread with a major tolerance of .485 to .478 and a minor tolerance of .448 to .443. I have a fanuc O-T control. Could someone out there help with the g-code I should use, I tried g32, g92, and g76 whiuch one is best. and could a sample program be provided? Any help would be greatly appreciated |
| thanks ghyman I entered in the info given it did indeed make a thread but the but the pitch was so fine it wiped out the major diameter!! I can get the pitch correct with a g32 but the threads come out full of burrs,and I 'd really like to use a canned cycle instead of punching a million numbers in manually. I got 1000 of parts to make and they get plated so they must be flawless. I bought this machine used and haven't had to thread anything until now. I have never run into this problem before I've been on the floor programing and machining for 15 years. I am using a g97,g99,g20 so that is all there. I am begenning to think bad encoder?????? |
| thanks guys I found the problem today a bad wire to my encoder as soon as I fixed the frayed wire it worked fine. Back making parts. I guess I learned a lesson getting a used machine at a bargin basement price will cause alot of head aches until you get all the bugs worked out. I can't afford a repairman at $150.00 an hour so I am on the learning curve. Starting you own shop is such a joy just waiting for the rewards.................. |
| Okuma LC-20 Threading problem | Gunner | Machine Problems, Solutions , Wireless DNC, serial port | 13 | 12-13-2011 10:11 PM |
| Deskcnc version that supports threading | Dan Mauch | Carken Products (Deskam, DeskCNC etc) | 1 | 04-04-2005 06:51 PM |
| Threading tool recomendation | Toddjones | Machine Problems, Solutions , Wireless DNC, serial port | 4 | 02-18-2005 12:55 AM |
| Four start threading using Mach2 ? | Bloy2004 | Mach Software (ArtSoft software) | 6 | 02-11-2004 10:57 PM |
| Taig lathe Threading and CNC questions | anoel | Mini Lathe | 5 | 01-12-2004 03:43 PM |
