| G-Code Programing Discuss G-code programing and problems here! |
I'm using a Puma 280L with a Fanuc 21i-TB controller, and I need to cut a 1/8-27 pipe thread in my parts. The tap goes in the part at X0, and goes to Z-.460.I was trying to use a G84 ridged tap cycle, but the book I have to use might as well be written in Korean. If someone could please give me a program for this,and maybe please an explanation of what each of the pieces of information in the cycle is there for. Thanks very much, Hacky |
__________________ The best way to learn is trial error. Last edited by CNCRim; 01-28-2010 at 05:10 PM. Reason: The manual is for milling center. oops |
| I got it to run. It seems the book was right after all. The lines of code you gave me were still a help dcoupar. The program that ended up working was this. T0404 M08 G99 G00 X0 Z.400 M29 S70 G84 Z-.590 R-.400 F.037 G80 M09 X Z go home M01 When I first tried this program it kept giving me Alarm 200 which is an illegal S command. The book said it was parameter 5241. When I checked it , it was set to zero. So I set the parameter to 80 to see what would happen, and it worked! I'll probably go back and up that parameter to about 500 so that the rpm will be there when I need it. dcoupar, the program you gave me made it give Alarm 205 which is, Rigid mode DI signal off. (whatever that means) Anyways, thanks again, you really did help me out. |
| Problem- center drilling: Out of center | skipper | General Metalwork Discussion | 8 | 03-01-2008 12:50 PM |
| new to cnc machining center | BruceinOZ | CNC Machining Centers | 6 | 08-11-2007 01:25 PM |
| New Machining Center | porsche1220 | CNC Machining Centers | 0 | 04-27-2006 06:34 PM |
| what to do with center tap? | truman | General Electronics Discussion | 21 | 01-20-2006 10:21 PM |
| Do I need to center drill? | jderou | General Metalwork Discussion | 9 | 06-15-2005 09:33 AM |
