Old 01-20-2010, 05:11 AM
radioman is on a distinguished road
ERROR?
hi guys does anyone know what i am doing wrong? i get the following message....'RADIUS TO END OF ARC DIFFERS FROM RADIUS TO STARTLINE 40'
NEW AND HAV'NT GOT A CLUE.
Old 01-20-2010, 05:40 AM
holbieone's Avatar
holbieone is on a distinguished road
if you posted your code , that would help us help you
Old 01-20-2010, 05:42 AM
holbieone's Avatar
if your using g2 or g3 you mite be missing a g1 or g0 for the next move
Old 01-20-2010, 06:10 AM
OK I used solid edge to draw a plate which is approx 300mm x 300mm roughly and then put some slots and holes in it .. opened it in the cam program and then generated the toolpath and the g code... opened the g code in mach 3 and when it loads it highlights line 43 (i think) and no drawing comes up in the toolpath display... it will not run... incidently this is my first cut on the machine i have just built... soft limit set to x= -300mm and 300mm y= -600mm and 600mm z= -90mm.
tried to upload .nc file but i will not let me line 43 reads
'G2 X401.451 l-15.1 JO.O
i have mach 3 on another pc in the study and the file loads and runs ok (without the cnc machine attached obviously)
Old 01-20-2010, 12:08 PM
chucker's Avatar
chucker is on a distinguished road
may be just a type O but your J has an O instead of a zero
Old 01-20-2010, 12:21 PM
CNCRim's Avatar
Either the starting point and the endpoint of the arc is not equation of the circle. Post your code ....... at least 3 lines where it kick alarm.
tl-2 program integrity error and program data error alarm #'s 212 250 need help CNChelp Haas Mills 12 03-14-2010 08:19 PM
Need Help!- Matsuura Mc500v seq error/magazine error mc500v General Metal Working Machines 10 01-08-2010 01:35 PM
Need Help!- Error 414 Z axis error detect- servo alarm andywids Fanuc 0 07-09-2009 10:33 AM
Need Help!- Error 414 Z-axis error detect servo alarm andywids General Metal Working Machines 1 07-09-2009 09:56 AM
OM-A ROM PARITY ERROR "NOT RAM ERROR" offroadxx Fanuc 9 05-07-2008 08:15 PM
