| G-Code Programing Discuss G-code programing and problems here! |
(MAIN) G28U0.0 G28B0.0 N10G00T1000M91 G00T1010(.437 ENDMILL ) M13 G28H0 G97S1000M44 G00G98Z.1 X2.0 G12.1 G0X1.1C1.1 G98Z-.5F30. G41G01X.686F20. C-.468 G40X1.1 G0Z.2 G00X-1.1C-1.1 Z-.5F30.M08 G41G01X-.686 F20. C.468 G40X-1.1 G00Z0.2 G13.1 M01 M30 |
| Have you used the G12.1 function on this machine before? The 145 alarm says that either: 1. G40 is not active when G12.1 is started or cancelled... this doesn't appear to be the problem with the code you posted. 2. The values of parameter 5460 and 5461 are incorrect. I would check these parameters just to be sure. 5460 should be 1 (for axis 1, which is X), and 5461 should probably be 3 (for axis 3, which should be C). Other than that, I see a couple of G0/G00 moves between G12.1 and G13.1. AFAIK, G0/G00 is not allowed when G12.1 is active. I would take these out or replace them with G1/G01 moves. Let us know. |
| As far as program, I don't see anything wrong, run the program without G12.1 but try to change your C.468 to C30. or bigger number and look at your location position and see what happen if it does move without alarm then your polar convertion parameter is still off.
__________________ The best way to learn is trial error. |
