Results 1 to 6 of 6
Thread: help with thread 1/2-8 2star on okuma osp7000l lathe
    Nov 2004
    hi i need help on writting the G code for threading 1/2-8 2star acme. i understand that 4 thread per in and 180 degree apart. i can cut first star at 0 degree, but i don't know how to cut the second star at 180 degree cuase i don't know it's there a command for the okuma lathe tell to rotate 180 than cut the second star.
    tex
    tex is offline
    Apr 2004
    Serbia and Montenegro
    Just a guess:
    M19 P180
    Registered mark c's Avatar
    Sep 2004
    US of A
    When I've done this on Fanuc controls, I've changed the starting Z value by the pitch of the thread, in other words, first start, Z.1, second start Z.35 etc
    Hope this helps
    Insanity "doing the same thing and expecting a different result"
    Mark
    www.mcoates.com
    Zep
    Zep is offline
    Jul 2004
    Mark is right , its a two part threading cycle with a shift amount
    I used IGF on my Okuma for the thread you asked about and this is the code it generated
    NAT05
    N0100 G00 X20 Z10
    N0101 G97 S800 M42 M03 M08
    N0102 X0.55 Z1.1 T050505
    N0103 G71 X0.3376 Z0 H0.1624 D0.032 U0.0016 B29 F0.25 M22 M73 M32
    N0104 G00 Z1.225
    N0105 G71 X0.3376 Z0 H0.1624 D0.032 U0.0016 B29 F0.25 M22 M73 M32
    N0106 M05 M09
    N0107 G00 X20 Z10 T0500
    N0108 M01
    please note values will need to be adjusted for your needs but format should be close.
    Dec 2005
    G71 X.5 Z-1.0 B90 D.01 H.1 U.001 F.125 M33
    VZSHZ=-.0625
    vzshz=0
    I run an Okuma Crown with osp7000l controls and this would work on my machine.
    vzshz is a variable z shift that moves the offsett what ever you make it equal.(-.0625 should make it 180 degrees from the first thread.)
    g71= thread cutting cycle
    x=start point of thread
    z=end point of thread
    b=angle of thread
    d= depth of cut
    h= thread height
    u=depth of cut for finish pass
    f=feed
    m33=in feed pattern(stagger)
    Make sure to set vzshz=0 after you thread or all of your offsets will be set back .0625.
    Registered broby's Avatar
    Apr 2006
    If you have the option... try a Q2 value on the end of the G71 cycle and hey presto you have a 2 start thread!
    ie... using the code from the above example...
    G71 X.5 Z-1.0 B90 D.01 H.1 U.001 F.125 M33 Q2
    This works on our machines.
    Cheers
    Brian.
    1. Okuma Lathe question
      By dartplayer1 in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 08-11-2006, 03:12 AM
    2. OneCNC XR Series Lathe CAD/CAM Released:
      By OneCNC in forum Product and Manufacturer Announcements
      Last Post: 03-07-2005, 05:20 PM
    3. Small lathe project, thread insert
      By impact in forum Employment Opportunity
      Last Post: 01-09-2005, 06:43 PM
    4. seeking thread cutting cncmini lathe
      By july_favre in forum General Metal Working Machines
      Last Post: 03-08-2004, 04:19 PM
