| G-Code Programing Discuss G-code programing and problems here! |
Im tapping 3 holes M3x.5 in 304 ss on a fanuc robodrill to get my feedrate do I do .5 x .03937 x 150 rpms??? to get my feedrate?? I never do anything in metric so not sure if my calculations are correct. Also a g82 spot drilling cycle axample would be helpful. Thanks! |
Thanks again for the replie Stevo! |
| Simple formula Feed per minute = Pitch x RPM If you alter the RPM at any time, the feed would also need re-calculating. Another common solution when tapping, is to use feed per rev ( G95 ), so the feedrate you dial in is the pitch of the tap, you can alter the RPM but the feed is still locked to the tap pitch and will not require adjusting. The only problem is that you must change back to G94 immediately after using the tap, to avoid the next tool having 10" per rev feeds, for example . ie.(tapping)(imperial) G95 G99 G84 Z-.75 R.12 F.0394 (M6x1.0mm tap) Xx.x Yy.y G80 G94 ie.(tapping)(metric) G95 G99 G84 Z-19.05 R3. F1. (M6x1.0mm tap) Xx.x Yy.y G80 G94 ie.(spotting)(G81 and G82 do the same thing-one CAM software outputs G82 if you put a dwell in the cycle) G99 G81 Z-.1 R.2 F.01 (90° spotdrill) Xx.x Yy.y G80 G94 Last edited by Superman; 12-30-2009 at 08:29 AM. |
| Hi There , I am new to The CNC Zone , and if any one could help, I want to do Metric Tapping on Fanuc 21M Control, its a Blind hole and need to Tap 5mm Tap , what could be the Feed Rate (.8pitch x300rpm=240 F ) is it correct or i should use any other M code Prior to this g84 line ? Please guide me |
| metric tapping | kurt_laughton | G-Code Programing | 5 | 10-02-2008 09:54 AM |
| Metric rigid tapping, TM 1 | Shop junkie | Haas Mills | 13 | 06-23-2008 04:18 PM |
| metric tapping | fourperf | Fadal | 2 | 12-14-2007 08:18 AM |
| Standard tapping and Metric Programming. | Dull Tool | General Metalwork Discussion | 3 | 02-01-2007 04:09 PM |
| Rigid Metric tapping... Need a bit of help | saabwagon | Haas Mills | 14 | 04-06-2006 06:17 PM |
