Old 12-08-2009, 05:12 PM
jessec is on a distinguished road
Start and End Radius differ
Hi
few questions about g code and sprut cam
-i am getting this warning inconsistanly , that the start and the end of my ark differ by more than .001 , is this something i am doing or sprutcams post processor is doing?
-is ther a way to generate code to the 4th decimal place , i wonder if this would help my radius problem
-is there a newer sprutcam 5.58/postprocesser than Jan 16/08 .
thanks
Old 12-08-2009, 05:49 PM
ger21's Avatar
Is your IJ Mode correct?
Old 12-08-2009, 07:03 PM
i am not sure what you mean by IG mode?
Old 12-08-2009, 07:22 PM
ger21's Avatar
What control are you using? If your arcs have I and J in them, there are two ways to configure the IJ mode. Absolute and Incremental,
Old 12-09-2009, 09:12 AM
dcoupar's Avatar
Why not post your code here. Maybe we can help.
Old 12-09-2009, 04:05 PM
yes my arc 's do have an I and a J in them
how do i change from incremental or absolute , whitch would you recomend?
thanks
Old 12-16-2009, 06:16 AM
Get lucky's Avatar
Get lucky is on a distinguished road
It really helps to have you code posted.
You must remember that 99% of my posts are Bullchit!
Old 12-16-2009, 11:08 AM
here is my code , it does have i's and J's
Old 12-16-2009, 12:24 PM
rowbare is on a distinguished road
What kind of machine controller are you using. If you are using Mach:
http://www.machsupport.com/docs/Mach...all_Config.pdf go to section 5.6.6 General Configuration (page 93). In the second column there is a group called IJ Mode with a pair of radio buttons. This value must match the value your post processor uses.
If you don't know what mode the post is using and it is failing, choose the other value and reload the g-code and see what it tells you.
bob
"Radius to end of arc differs from radius to start on Line #" labuda G-Code Programing 8 11-15-2009 06:35 AM
Need Help!- Radius to end of arc differs from radius to start? Jamy LinuxCNC (formerly EMC2) 2 08-22-2009 11:28 PM
Problem- Meshcam and Sheetcam cooridinates differ? KenoSlim GRZ Software- MeshCAM 5 07-07-2008 11:30 PM
Drawing Size and Cut Size Differ - Plasma ADucci LinuxCNC (formerly EMC2) 5 10-05-2007 04:52 AM
Drawing Size and Cut Size Differ - Plasma ADucci Mach Plasma / Laser 0 10-04-2007 08:49 AM
