Old 03-27-2005, 07:50 PM
osdhillon is on a distinguished road
CATIA G-code conversion
I need help in converting CATIA v5 APT code into G-code. I am using Mach2 Controller software. Does anybody use CATIA v5 to machine the parts?
Onkar
Old 03-28-2005, 03:44 AM
tex tex is offline
tex is on a distinguished road
Originally Posted by osdhillon
Onkar
I do. Just tell me the exact problem you've got...making G-code is very simple in CATIA.
Old 03-28-2005, 10:22 AM
Well I designed my part in CATIA v5 Release 13. In prismatic machining I was able to make machining process. Later I was trying to generate NC code and am able to save NC data as APT code. I am not sure which post processor file to use. I selected some and it gave in 'N' codes.
If you can please explain how do you generate G-code that would help me a lot. I am using Mach2 for my home made CNC router
Onkar
Old 03-28-2005, 01:09 PM
tex tex is offline
I am not able to help you with your choice of actual post processor, you have to give it a try and find out which one suits you best. I recommend you choose IMS Post Processor in Tools-Options-NC Manufacturing-Output.
I'll assume that you have defined the Manufacturing Program correctly. Open Part Operation.1 (from the tree), then Machine. There, under the Numerical Control tab you could try PPTableSample.pptable for Post Processor words table and haas.lib for Post Processing as a first choice. Be sure to input values for Min interpol. radius and Max interpol. radius, otherwise you'll have no circular interpolation.
Now you have to highlight the Manufacturing Program from the tree and select "Generate NC Output in Batch Mode" from the toolbar. Under In/Out tab you'll choose NC Code as your NC data type. Choose the name and the path of the output file and click Execute. Wait until the DOS prompt window disappears (if it wants you to input the program number do so) and you'll get your G-code.
I see that you have mentioned that you had managed to get a code with N codes...that is exactly the way your G-code should look like. In case your controller does not recognize line ("N") numbers, just erase them in a G-code editor.
Old 05-15-2005, 09:08 AM
tex tex is offline
Well, osdhillon, have you managed to get your G-code or what?
Old 05-15-2005, 02:28 PM
Hi Tex,
Yes, I was finally able to. I have two versions of CATIA and I have having hard time to direct to the right directory to PPT sample file, but in the end I got it. I am still in learning process. I am good in CATIA but haven't used the NC package much. I went through the tutorials and it seemed pretty easy. I am about to finish converting my mill into CNC and then I am building a CNC router (As Proffesional as the budget will allow) and I will be using CATIA to design and NC.
Thanks for your help
Onkar
Old 05-17-2005, 07:57 AM
tex tex is offline
I'm very glad to hear this.
CATIA has great CAM modules...
Old 03-04-2007, 07:22 AM
kmukundank is on a distinguished road
i can also proceed upto creating apt but i dont know how to post is post is diabled in pirated let me know
Old 03-04-2007, 06:46 PM
tex tex is offline
AFAIK any version of CATIA is able to create G-code and not APT only. Check out my previous posts. Of course, you have to choose IMS (for instance) post-processing in Options first.
Old 08-22-2007, 09:51 AM
foto1232002 is on a distinguished road
Urgent... CAtia to G-code
i'm using catia to draw my part . Which feature in the catia can generate G-code. I never learn before. some one can help me. I'm very urgent because in one month i need to produce a part for my final year project before gratuate.PLZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
  #11   Ban this user!
Old 08-08-2008, 09:50 PM
labuda is on a distinguished road
Does anyone know of any tutorials for machining in Catia V5?
I'm willing to pay if it'll be a good tutorial.
thanks
  #12   Ban this user!
Old 08-09-2008, 04:00 AM
tex tex is offline
thanks
Do you have the original CATIA V5 help, it could be very useful if you are familiar with CATIA in general?
For beginners this could be useful:
http://www.sdcpublications.com/1-58503-321-9.htm
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 10:21 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 03:58 PM
First Impressions for CNC mini mill conversion CNCadmin General Metal Working Machines 4 11-16-2004 09:37 PM
I need sample G code program bunalmis G-Code Programing 1 08-24-2004 04:50 AM
Getting The Most Out of CNCzone's Posting Features CNCadmin CNCzone.com FAQ 0 03-02-2003 12:08 AM
