| G-Code Programing Discuss G-code programing and problems here! |
I haven't programmed much live tooling on my Mori NL2000 lathe and I'm running into a problem. I'm more of a mill guys so I'm not exactly sure if I'm doing this correctly. Here's the program I have using cutter comp on the finish pass cutting a slot. The basic shape of the slot is a 10mm wide slot that travels in the Z axis 28mm, rotates 90 in C, then backtracks in Z 3mm to form a kind of J shape. I'm using a .25in endmill to finish with. When it cuts the section in bold it moves the cutter comp to the right side of the line. I have a -.005in offset in my tool and everything cuts left until that part. It offsets the Z-2.2515 that's programmed to Z-2.2565 instead of the Z-2.2465, which would be on the left side of the line. If anyone could help me out that would be great. For now I'm just going to cheat and just change the Z value over to what I need so the boss isn't staring at unfinished parts. T1010 G19 M45 G98 G0C0. X2. G0G90G56Z-.777Y.0115S3733M13 X1.475 G1X.6F10. G41D10Y-.0215F20. G3Z-.827Y-.0715R.05 G1Z-2.323 G3Z-2.3945Y0.R.0715 G1C90.F500. G3Z-2.323Y.0715R.0715F20. G1Z-2.205 G3Z-2.1764Y.0655R.0715 Z-2.1335Y0.R.0715 Z-2.1734Y-.0641R.0715 G2Z-2.2515Y-.1897R.14 G1Z-2.280 Y0. Z-2.2515 C0.F500. Y.2745F20. G2Z-2.0485Y.0715R.203 G1Z-.827 G3Z-.7555Y0.R.0715 Z-.827Y-.0715R.0715 Z-.877Y-.0215R.05 G1G40Y-.0115 G0X3. |
| Cutter comp problems | scottsss | G-Code Programing | 49 | 11-30-2011 10:47 PM |
| cutter comp on c-axis | Bigbill | Daewoo/Doosan | 2 | 10-20-2009 12:07 AM |
| 3-axis cutter comp? | ghyman | G-Code Programing | 15 | 06-28-2009 11:54 PM |
| Cutter Comp Problems | JWB_Machining | Haas Mills | 3 | 12-07-2008 06:13 PM |
| Cutter comp on an id hole< cutter diam.?? | PaintItBlue | Haas Mills | 5 | 05-05-2008 06:30 PM |
