  #13   Ban this user!
Old 03-25-2005, 03:40 AM
santiniuk's Avatar
santiniuk is on a distinguished road
Joe, really impressive.
Would you mind sharing what steps / software you used to do that please.
I'm also heading along the lines of xairflyer but there's so much to learn.
Thanks.
  #14   Ban this user!
Old 03-25-2005, 05:50 AM
xairflyer's Avatar
xairflyer is on a distinguished road
Thanks Joe I will let you know how it went.
Old 03-25-2005, 06:24 AM
ger21's Avatar
Originally Posted by xairflyer
I can't seem to get any of them to give me the outline of the logo and end up with bits of it or in a 3D form which I dont want.
What he's giving you is 3D, but you said that's not what you want?
  #16   Ban this user!
Old 03-25-2005, 07:51 AM
xairflyer's Avatar
Yes Ger I have just realised that this morning when I went to run it, As my machine at the moment (still using 12v and 8mm all thread) is only doing about 12in min it would take for ever to cut like this.
Joe when I looked at your first picture it looked like to me that the logo was cut out of the material rather than the material cut around it.
What I want to do is cut the logo out of the lexan like picture below.
I have been able to get some sucess with 3d conversions with deskart but again not what I want.
Name:	cnc 285s.jpg‎
Old 03-25-2005, 08:33 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
The g-code does cut the logo into the material, you may want to run it on a scrap wood 1st, thats what i always do, and also set the z zero just above the piece to 0.02mm this will avoid the 0.005 and the 0.017 cuts into the work piece around the logo.
Joe
Old 03-25-2005, 08:47 AM
ger21's Avatar
Joe, he just wants to make 1 pass around the outside, not carve it.
Old 03-25-2005, 08:53 AM
joecnc2006's Avatar
www.joescnc.com
Ok, I will see what i can do with it tonight, I have the pic on my laptop.
  #20   Ban this user!
Old 03-25-2005, 09:30 AM
troyswood's Avatar
troyswood is on a distinguished road
here is the proceedure I looked at your picture on the screen and on the keyboard (depress print screen sys rq). then open paint or photo shop or picture software. top left of screen edit paste. then save as(what ever) now I use bobcad/cam v19 and bobart 2d 3d it took me less than ten minutes to cut your pic from start to finish.
if you need help email me troyswoodworking@msn.com or call anytime troys accurate machining wood and metal Troy S Mariotti clinton twps michigan 586-412-9681
bobcad/cam is very easy to use!!!
Name:	girl milled outline in pine.jpg‎
  #21   Ban this user!
Old 03-25-2005, 05:02 PM
xairflyer's Avatar
That looks good troyswood, unfortunatly I really can't afford $1500 for bobcad/cam as good as it seems to be, I would',t mind paying the $175 for deskart if I thought it would do the job. If I can learn how to use the trace in autocad like was suggested it will have to do for now.
The picture of the girl was only what I was telling Joe what I wanted to do with the Logo at the top of the thread.
  #22   Ban this user!
Old 03-26-2005, 05:58 PM
xairflyer's Avatar
Anyone know is there any other programs out there that specificlly deals with engraving other than deskengrave
  #23   Ban this user!
Old 03-26-2005, 06:07 PM
id 10 t is on a distinguished road
Hello xairflyer,
Have a look at these programs:
CAD-KAS Paper/Picture 2 DXF 1.0
http://www.cadkas.de/downengcad.php
Adobe Streamline.
There is a video tutorial here http://www.great-lakes-training.com/tutorials.php
(Click on Create CNC Programs From Scanned Images)
Coreldraw
There is a tutorial here http://engraving.majosoft.com/
(Click Cheap Cad Cam)
Is it possible to get a gcode into Rhino MrBean Rhino 3D 11 04-03-2005 07:41 AM
AutoCad Designed Logo gopackgo Autodesk Software (Autocad, Inventor etc) 3 11-24-2004 12:28 AM
gcode to gcode converter july_favre General CAM Discussion 4 05-24-2004 06:51 PM
dxf to gcode problem... freezer General CAM Discussion 9 02-19-2004 12:02 AM
Gcode verify autocad plugin balsaman General CAM Discussion 1 10-31-2003 11:22 AM
