Old 11-12-2009, 07:41 AM
cdntoolmaker is on a distinguished road
How do I program turning a ball on the end of a shaft?
Hello everyone,
I was wondering if anyone out there can tell me how to write a program that would turn a 3/4" dia. ball on the end of a shaft? Are there any wizards or macros to help with the programing? Any help would be greatly appreciated.
Thanks,
cdntoolmaker
Old 11-12-2009, 05:02 PM
uperez is on a distinguished road
Hi! It's easy if you're using a round insert. Just simply add the radius of the part and the radius of the tool in your R value in the program. You just have to calculate the starting point in z if you're starting the arc from the shaft side, or the end point in z if you're starting the arc from the ball end side since your shaft diameter must already be given then the X value is already known.
PS: this is if you are not using tool nose radius compensation (G41/G42).
Old 11-13-2009, 12:21 PM
Hi uperez,
Thank you for your responce. I don't think I stated my question properly. I'm looking for instructions on how to write the actual code. I am new to programing and I have been using Mach3 and Lazycam to generate my 2 1/2D code for milling applications. This is my first try at Lathe cnc. My sizes are on the end of a 0.3125 dia. x 1.500 long shaft there would be a 0.750 dia. ball. So once again any help would be greatly appreciated.
Thanks,
cdntoolmaker
Old 11-13-2009, 03:17 PM
dcoupar's Avatar
I'm confused. How do you get a 0.750 diameter ball on the end of a 0.3125 diameter shaft? Can you post a picture of what you want?
Old 11-14-2009, 07:28 AM
Hi dcoupar,
You ask. "How do you get a 0.750 diameter ball on the end of a 0.3125 diameter shaft?"
I could do it two ways.
1) Thread one end of a 0.3125 dia. x 1.500 shaft and screw a 0.75 dia. x 0.75 blank on the end and then turn the ball.
2) Start with a 0.75 or 0.875 dia x 2.25 long blank. Face and turn one end to 0.3125 x 1.5 long. Then mount the 0.3125 end in the cnc lathe and turn the ball.
For turning the ball end I would be using a 0.094 wide top notch carbide insert with a full radius on the tip. The cnc lathe it would be turned on is the size of a sherline so I would not be able to hog off the rough cuts. Maybe roughing passes of 0.020 and finishing passes of 0.005. I believe the control is very similar to the Fanuc G&M codes because it needs a % sign at the beginning and end of the program.
Once again, any help would be greatly appreciated. Thanks.
Tags
ball turning, programing?, radius turning
turning ball screws meincer Benchtop Machines 10 09-06-2008 02:13 PM
lathe turning a ball screw end margni74 General Metalwork Discussion 14 12-04-2007 09:57 PM
turning motor shaft to smaller diameter smoker General Material Machining Solutions 5 03-08-2007 09:56 PM
Source for large qty of cheap linear ball bearings - round shaft InspirationTool Linear and Rotary Motion 2 01-10-2007 09:00 AM
turning ball screws Runner4404spd General Metalwork Discussion 11 02-15-2006 10:58 PM
