| G-Code Programing Discuss G-code programing and problems here! |
I am using G75.1 P100 Q200 U0.200 W0.200 I6.000 K0.0 D6.00 F0.4; on a Mitsubishi CNC lathe in metric with G95 where D=no of cuts & I and K confuse me. Q1: How do I work out my depth of cut? Q2: Is this the only material remove cycle I can use to cut from right to left with a LH tool? |
| D = repetative count ( Number of passed you want to be taken) K = Distance & Direction of relief in the Z axis I = Distance & Direction of relief in the X axis ( Radius Programming ) This is what is used for a fanuc control I believe that all is the same except fanuc calls a G73 for the profile cycle Hoe this helps |
| Strange cutting pattern | owhite | Laser Engraving & Cutting Machines | 4 | 03-13-2005 11:48 AM |
| Opticeye pattern cutter | DHB | CNC Plasma and Waterjet Machines | 3 | 02-24-2005 10:07 AM |
| Repeat g-code with y offset | tpaulson | G-Code Programing | 19 | 11-29-2004 02:36 PM |
| Repeat lathe tools | steveo | Mastercam | 2 | 05-03-2003 12:42 PM |
| Pattern Systems | DanFri | General CAM Discussion | 10 | 05-02-2003 11:55 AM |
