| G-Code Programing Discuss G-code programing and problems here! |
Not sure where th post this but, I have a DXF that I converted to gcode using "DFX2GCODE". Worked fine but when opening it in EMC2 it is wider then it is tall or in other words, it is to long in the Y axis. X is fine and the longest axis on my machine. How can I turn this so the long way lies in the X axis? Thanks Carl |
| Simplest is to open the DXF file in a CAD system and rotate the entities 90° and re-save to a new DXF file and run again through "DXF2GCODE" or Open the NCfile with a text editor and insert a rotate command ( check your manuals for correct G-code and syntax ) at or near the top of the program. Don't forget to cancel the G-code at the end of the file If you are using multiple tools, rotation may need to be cancelled when toolchanging |
| converting a mastercam 9 file into a Solidworks file | Michael82 | Solidworks | 5 | 04-17-2009 01:14 PM |
| Need Help!- Need a favor. STL converted to part file or solidworks part file. | Cmzwirner | Solidworks | 3 | 12-11-2008 07:45 AM |
| mill/turn on a cin turn | Robert Timby | General Metal Working Machines | 4 | 01-31-2007 10:33 PM |
| Cin Turn turn/mill | Robert Timby | General CNC (Mill and Lathe) Control Software (NC) | 0 | 01-24-2007 07:12 PM |
| Is There A Pdf File Just For Mach2 Turn | CATCH22 | Mach Lathe | 2 | 08-02-2005 09:35 PM |
