Old 10-06-2009, 02:46 PM
JHECNC is on a distinguished road
Torque Control on B-axis
I have a Daewoo Puma 200SY with Fanuc 18i-TB control and am trying to utilise the torque control on the B-axis for turning long parts.I have posted a question about this on the Daewoo/Doosan Forum but as yet have had no replies (lots of views though).
I have tried programming a "G300 B-200" as stated in the programming manual available on this site but the m/c bombed out and I got an error message...."Part off failed".
after a bit more digging I tried the program below but had to reposition the centre again before the finish pass due to vibration
Tool Call G54 etc.
G98
G00 B-257
M86
G31 P99 B-280 F100
M87
G99
G96 S200 M203
"Rough"
"Finish"
ended up as :
Tool Call G54 etc.
G98
G00 B-257
M86
G31 P99 B-280 F100
M87
G99
G96 S200 M203
"Rough (G71)"
"End tool"
"Call up finish tool"
Tool Call G54 etc.
G98
G00 B-257
M86
G31 P99 B-280 F100
M87
G99
G96 S200 M203
"Finish pass (G70)"
End Program
Can any one help with the correct format of G-Code for this op ?
Martin
Old 10-19-2009, 09:41 PM
muddobber76 is on a distinguished road
Are you still having trouble with this? I you this same function on one of our Takisawa mill/turns with 18i. The code looks the same. Let me know I'll give you what I use.
Old 10-20-2009, 04:17 PM
Yes,still no wiser,I would appreciate any help,If you could post me up a sample program that would be great.
Just for a bit of background here is where it all started :
http://www.cnczone.com/forums/showthread.php?t=82592
Many Thanks
Martin
X axis torque alarm on Takisawa Lathe lkenney General Metalwork Discussion 3 08-27-2009 02:14 PM
Newbie- Regarding Torque Control Aquawhite Servo Motors and Drives 0 11-18-2008 09:30 PM
Taig Z Axis Column Torque? Manual? cwm9 Taig Mills & Lathes 3 11-17-2008 10:00 PM
Torque Control xavierdemoura Fanuc 0 03-12-2007 04:43 AM
Which axis needs more torque (X,Y,Z)?? campaX DIY-CNC Router Table Machines 4 07-31-2003 01:28 PM
