Old 03-11-2005, 06:28 PM
cncwhiz is on a distinguished road
Question Thread mill programming software?
I currently use "greenfield" thread mills. I had a program that a guy that used to work there built in execl. You would plug in the necessary data and out would pop a thread mill program written in incremental g code. I currently run pro manufacturing and it will program a straight thread but a npt thread is not a standard feature. I have one from Melin tool but it only makes one pass? Does anyone know where to find this software?
Old 03-11-2005, 10:25 PM
brtlatjgt is on a distinguished road
Try Advent tool. I believe you can download their software. In the software you have the ability to enter a custom tool-your greenfield threadmill specs. Hope it works for you.
Old 03-12-2005, 06:48 AM
oldjohn's Avatar
oldjohn is on a distinguished road
Smile
G'day
Seco Carboloy has a free Thread Milling Wizard you cam download from their site
http://www.carboloy.com/wizard/default.htm
Oldjohn
Old 03-14-2005, 02:08 PM
Thanks guys,
I downloaded the Carboloy software last week. I works good but only cuts in 1 pass. I downloaded the software from Advent tool and it id doing what I want. Both software's are good. The Advent is a good program. It is a little harder to use until you figure it out. The Carboloy is a easier software to use but I do some pretty small thread milling and it works better with two passes. Melin also has a free download but does one pass as well. So in closing, All three are good but the Advent software did what I needed.
Thank you.
Old 03-16-2005, 06:19 AM
Bill Johns is on a distinguished road
You could use circular interpolation with a z move. Then step the pitch in z and do it all over again. Have used that before.
Old 03-16-2005, 10:12 AM
Sure you can do that if you are doing a standard thread. Try to do that with a pipe thread. You have a correctoin factor of between .0003 to .002 depending on what pipe thread your doing. This is why I use this software. I run pro e and it will do standard threads.
Old 12-31-2008, 02:48 PM
ulav8r is on a distinguished road
Micro100 has spreadsheets to write one or two pass programs for UN and NPT threads.
I found them when I did a Google search for "thread milling program". This thread came up about three lines below the Micro100 site.
SpectraLIGHT Mill SOFTWARE? HELP? Brokengears Benchtop Machines 7 01-13-2007 07:40 PM
Any options for an old mill? bjorn General CNC (Mill and Lathe) Control Software (NC) 1 03-04-2005 11:55 AM
Which CNC Mill and what software? MaxxMan-X Knee Vertical Mills 16 04-18-2004 12:25 PM
Free Software for my minitech mill moose Benchtop Machines 0 03-26-2004 12:46 PM
