Old 09-24-2009, 08:20 AM
chucker's Avatar
chucker is on a distinguished road
Mill a Square with C and X Axis?
We have a Daewoo Puma Inverturn 3000M with a Fanuc 18i-TB control. This machine has live tooling and C axis capabilities I need to mill an ID square into the face of the part is this possible with just the C and X axis the square is 3.015 by 3.015 with .375 radius in the corners using a ½ inch end mill if it is possible could some one post some sample g code I am drawing a blank on this one.
Old 09-24-2009, 08:29 AM
dcoupar's Avatar
I believe that you have the Polar Interpolation option. Maybe this will help.
Old 09-24-2009, 01:48 PM
chucker's Avatar
Mill Square with C and X Axis?
Thank you for the PDF it is very helpful
Old 09-29-2009, 04:17 AM
oldjohn's Avatar
oldjohn is on a distinguished road
Check on these files. Square generator and Ellipse generator.
Old 10-11-2009, 03:02 PM
charger19690 is on a distinguished road
XY Program to XC
I just had a recent experience where we used XY program with a G-Code which translated it to XC on a Haas.
Can read about it here...http://www.cncbasicsforum.com/index.php?topic=79.0
Kinda neat for straight up programming. I guess other lathes have similar codes out there. Fanuc and Haas are pretty close for codes, so a Fanuc might have the same feature.
Mike in MN
http://www.cncbasics.com
http://www.mastercamforum.com
http://www.mastercamblog.com
www.cncbasics.com www.mastercamforum.com
Old 10-11-2009, 07:44 PM
dcoupar's Avatar
Yes, it's called Polar Interpolation. See post below.
Old 10-11-2009, 07:48 PM
Thanks for the Terminology.
Don't do much on Lathes.
Mike in MN
Old 10-11-2009, 07:54 PM
After looking over the PDF on this site I am a bit confused. Like I say, I don't do much on lathes..
In my example, we took a XY program spit out of Mastercam Mill and just loaded that program in our Haas. We called up the G112 before the XY program and the machine interpreted the XY linear moves to XC moves.
Is this the same a Polar Interpolation or is this something that Haas just offers as a Linear translation?
Mike in MN
Square shoulder end mill efficiency!? zaebis General Metalwork Discussion 1 09-08-2009 09:29 PM
enco 45 square column mill atomize Benchtop Machines 11 10-19-2008 03:46 AM
Knee Mill vs Square Column Mill HimyKabibble Bridgeport and Hardinge Mills 0 11-09-2007 06:27 PM
Lathemaster Square Column Mill ? Willyb Benchtop Machines 13 06-01-2007 05:34 PM
Interesting Big square column mill davo727 Benchtop Machines 27 05-13-2007 03:23 PM
