Old 09-17-2009, 09:04 AM
twehr is on a distinguished road
Red face 4th-Axis GCode Programming
Need clarification on GCode for 4th axis.
What is the "unit" of movement for a 4th (or any rotary) axis? Is the 4th axis measured in inches/millimeters (of head-relative movement) like X,Y, and Z, or degrees/radians (of rotation), etc. It is easy enough to make either set of calculations, but have not worked with (or seen) rotary axis code.
Old 09-17-2009, 09:12 AM
It could be machine specific. I use Haas machines with a 4th axis (A) and it is programmed in degrees. These machines have the ability to Circle Wrap which means they map the X or Y axis onto the A axis and for this you need to input a diameter value which the machine then uses to convert between linear measure and angular measure.
Old 09-17-2009, 09:28 AM
Red face
Either way, it is going to come down to calculating the amount of rotation necessary to "move" the head a specified distance. I am, in fact, doing a project that involves wrapping a 2D image around a cylinder. (Laser work)
I had considered the axis-swapping approach, but still need to derive appropriate "units." Since I will be also building my own 4th-axis, it sounds like I can do it however I wish. Just did not want to do something totally contrary to the rest of the world.
Given your answer - that it is machine specific - I could write the application to allow users to choose their method, producing code that is likely to be compatible with their specific setup.
Thanks for the quick response - adds to my knowledge bank!
Old 09-17-2009, 10:35 AM
Jitendra Tomar is on a distinguished road
It depends on your machine, if your 4th Axis is Linear Axis unit would be in INCH/MILIMETER, and if your 4th Axis is a Rotary one unit would be in degree.
Old 09-17-2009, 10:42 AM
Red face
So, if user indicates they are mapping X or Y (I am working in 2D Laser), OR they have their Z axis directed to the rotary axis, then it is, by default, linear. BUT, it they indicate they are using the A (or B or C) axis, it should be, by default, degrees?
That is what I really wanted to know, but did not ask clearly - "What is the normal unit of measure for the A, B, or C axes?"
Thanks! That is very helpful!
Old 09-17-2009, 03:03 PM
stevo1 is on a distinguished road
I have only setup and seen these axis in degrees. I would consider that to be the norm. But there is always someone to disagree.
Stevo
Old 09-17-2009, 06:31 PM
dpuch is on a distinguished road
From what I have seen, default to degrees motion. It sounds like you still need this, so add a G code to change behavior. Much like Geof described.
An example might be:
G0 X-3.0 Y 0.0 A85.0 (position Y0.0, center of cylinder at rotation for start of laser marking)
G201 Z2.0 (G201 made up code to trigger modal wrapping around A at 2.0 radius)
G1... (code in XY that the control translates to XA moves)
G200 (return to normal XY mode)
Tags
4th axis, gcode, measurement, units
Need Help!- Can Bobcad be coaxed into making gcode for a 4 axis hot wire machine? seanreit BobCad-Cam 14 06-03-2010 03:56 AM
Need Help!- 4th gcode axis problem fabconv Visual Mill 1 08-29-2009 07:39 AM
Editing Gcode in excel for 9 axis CNC ?? imanflash G-Code Programing 5 03-23-2009 10:56 AM
What is the gcode to ref 1 axis home after seanreit General Metal Working Machines 6 12-07-2008 04:18 PM
Toolchanging and offsets gcode programming ddanutz G-Code Programing 12 11-04-2006 04:39 PM
