Old 09-14-2009, 07:01 AM
jorgehrr's Avatar
jorgehrr is on a distinguished road
Robo drill
Hello -
I need to program a radius of .075 and I did it as follow:
This is just the radius of .075 in a corner using a .312 end mill.(this is the part of the program with the trouble, we are not getting the radius).
Tool is already at X0.0.
I hope I'm giving enough info.
G2X.234Y-1.154R.075F15.
Incremental
G91G2X.075Y-.075R.075F15.
questions:
-does the size of the tool matter??
-do you need to program "X" always first???.
Please any corrections will be appreciate it
Jorge
Old 09-14-2009, 10:26 AM
stevo1 is on a distinguished road
Jorge,
I am a bit confused. When you say inside a corner are you trying to do a female radius?? Your tool plays a part with female radiuses. you cannot spin a female radius smaller than your tool radius.
IIRC it won’t matter if X is before Y.
Stevo
Old 09-14-2009, 04:32 PM
SBC Cycle is on a distinguished road
Stevo is correct. The X - Y order doesn't matter when it's in the same line (assuming the control is following ISO standards). And if this is an internal radius (like in a pocket) and you are using cutter comp, the machine can't do a radius smaller than the tool's radius.
Post more of your program if you can.
Old 09-16-2009, 12:50 PM
jorgehrr's Avatar
Thanks guys -
Sorry, couldnt get back here earlier.
This is NOT a packet.... From a chamfer, they wanted it to change it to radius. (do not know why). Im trying to replace the .075 x 45deg. to a .075 R.
Thank you guys for yopur replays
Jorge
Old 09-16-2009, 01:17 PM
beege's Avatar
beege is on a distinguished road
Originally Posted by jorgehrr View Post
questions:
Jorge
Jorge,
If you are programming a radius,
The size of the tool matters for INSIDE corners (<180°)
but not for OUTSIDE corners (>180°)
the order of words (X, Y, Z, R) is not important on most machines, but its best to get in a good habit, and stick with it so as not to confuse yourself or others later on. That said, if X doesn't change, for the most part you can leave it out entirely.
As to you problem, why don't you post the SECTION of code that's giving you trouble, and we can troubleshoot the whole path, and give you a clear understanding of why it doesn't work the way you have it now.
Old 09-18-2009, 09:40 AM
jorgehrr's Avatar
Thank you guys.
We found out the trouble.
Some parameters and macros were altered to be able to use G13 - G12 (circle cutting) but by doing that they create a problem for the codes of circular interpolation.
Big mess. The program was written right.
Thank you again to all.
Jorge
Need Help!- Robo-Drill with pallet changer sul1 General Metalwork Discussion 0 10-27-2008 10:06 AM
Fanuc 14T Robo drill jorgehrr Fanuc 4 10-14-2008 09:11 AM
Robo drill Fanuc 16 - 18 jorgehrr G-Code Programing 5 04-02-2008 05:04 AM
anyone have a Fanuc drill mate or robo drill? goodplastics G-Code Programing 1 07-22-2007 10:36 AM
fanuc drill mate / robo drill post for enroute? goodplastics Post Processor Files 0 07-19-2007 05:49 PM
