Old 03-06-2005, 09:51 PM
maxxgraphix is on a distinguished road
DXF export from Corel - Text cutting
Is this the only way?! I export from corel as DXF V10, import into BobCad, and I have to select these tinyline/arc segments in the middle of each letter to move to layer 1!
Why are the line/arc segments broken? The font was converted to curves before exporting. This always works with vinyl cutters. A 3 Axis router is only 1 axis more than a vinyl cutter. So what, you're only changing the Z.
You have to cut the middle first, then cut the outside when cutting completely through. So, any text must be in 2 layers.
Seems by default "Mach2" always cuts outside first. This will cause the font letter inside to rip out.
Ideas?
Old 03-07-2005, 12:12 AM
TinkerDJ is on a distinguished road
In corel you need to change the order that the objects are in. I use the trace tool and then seperate the seperate objects. After that you can put the objects in the right order for what to cut first. Other then that you may want to try double sided tape or something. I'm interested in how this works out for you, so make sure and update us if it works for you.
Have a good one.
Dave
Old 03-08-2005, 03:12 AM
h_2_o is on a distinguished road
this was discussed previously, well maybe not exactly but something similar. if you just need text to dxf check out ttf2dxf http://home.carolina.rr.com/gcodemcode/
hope this helps you out
Old 03-23-2005, 10:12 PM
OK, sorry about the delay. The way to do this is to convert text to curves. Select the innner parts and move to a new layer. Export out as DXF v10. Import into bobCad and select all then select the optimize feature. Save it. Load the DXF into Mach2, set your layer depts and speeds, generate G-Code and cut.
anyone know of a freeware program to turn text to dxf? ljoe1969 Autodesk Software (Autocad, Inventor etc) 7 01-18-2012 09:52 AM
single line fonts? balsaman General CAM Discussion 12 02-18-2006 12:51 PM
Rhino dxf export Ursine Rhino 3D 11 04-25-2005 11:57 AM
cutting text with a router CNC Darren DIY-CNC Router Table Machines 7 10-14-2004 06:04 AM
Getting The Most Out of CNCzone's Posting Features CNCadmin CNCzone.com FAQ 0 03-02-2003 12:08 AM
