| G-Code Programing Discuss G-code programing and problems here! |
| Just wondering if anyone knows a way to make SolidCAM generate the feed rates including the . at the end of the command. eg:- it generates it as G1 Z-3. F100 Y27.45 F600 but for the HAAS VF-03 machine we are using it requires to be G1 Z-3. F100. Y27.45 F600. The only difference is the period at the end of the feed rate. Any help would be greatly appreciated. Also does anyone know what M29 is? In the list we have, it does not exist and the machine won't accept it. Is there a way to stop that as well? |
| Although I can’t help you with the Soildcam stuff there should be a way to set up the machine so it does not need the decimal point in the program. I don’t have any of my machines set up to need the decimal. To many chances for errors if it is forgotten when programming. I have seen people program a 5 instead of 5. for a clearance plane . I am not sure what parameter it is in the Haas you will have to look it up. It should be under the parameters related to programming and labeled as “conventional” method or “calculator” method. You want calculator method.The M29 on most machines is rigid tapping mode. If your machine is not accepting it then you must have another code for rigid tapping or it is not needed. Stevo |
| Solidcam output weird Gcode | kn6398 | Solidworks | 3 | 03-18-2009 07:55 PM |
| Editing SOLIDCAM std FANUC gpp file | almo0797 | Post Processor Files | 1 | 01-25-2009 10:42 AM |
| Solidcam turn-mill postprocesor fanuc | costR | Post Processor Files | 9 | 12-10-2007 02:40 PM |
| I have a problem with my gcode or my conversion to gcode , everything is tiny? | NickLatech | G-Code Programing | 0 | 03-10-2005 12:46 PM |
| gcode to gcode converter | july_favre | General CAM Discussion | 4 | 05-24-2004 06:51 PM |
