Old 08-24-2009, 10:57 PM
Delanoman is on a distinguished road
Newbie-> Using G Code to turn a relay on
I have a relay BOB that i bought off of ebay. i wanna use this board to turn my plasma torch on and off. So far I have enabled 1 output under pin 17 (the pin which controls this relay). How do i get mach3 to know that this pin should be controlled every time my G-code tells it plasma on/ off. I made my G-code using lazycam.... If anyone can help me out thanks!
Old 08-26-2009, 11:59 PM
fizzissist's Avatar
fizzissist is on a distinguished road
Why not just use the M7/M9 (spray mist on/off) function? Most machines will have a regular 110V outlet powered by the command, which could be used to power a relay.
An OPTO22 solid state relay is great for 5V signals, btw, and they're cheap.
Old 08-27-2009, 12:11 AM
H.O H.O is offline
H.O is on a distinguished road
It depends on which M-code you want to use to operate the relay. M3 sounds like a good option since that is spindle ON (CW) normally.
Got to Config->Ports & Pins, Spindle Setup tab. Upper left corner, uncheck the Disable Spindle relays checkbox and set the Clockwise (M3) Output # to 1 - done.
Now M3 will turn on the relay and M5 will turn it off.
/Henrik.
Old 08-29-2009, 10:58 PM
Yeah i made sure the the spindle wasn't disabled. As for using different commands aside from M3 and M5 i have yet to try. here is a link to the relay board i bought off of ebay. http://cgi.ebay.com/CNC-PLASMA-ROUTE...4.c0.m14.l1262
Old 08-29-2009, 11:33 PM
srmurugavel is on a distinguished road
May i know what for code G64 is been used?
relay to turn plasma on needed with bob campbell Wolfesmetalfab General Electronics Discussion 11 01-04-2009 02:26 PM
Need Help!- G-Code to turn on and off router, non-spindle Sam A G-Code Programing 6 10-24-2008 08:02 PM
G-code manual for Mach3 turn? Green0 Mach Lathe 4 06-25-2007 07:57 PM
Newbie Q. How to turn LONG, THIN form? pipefettler General Metalwork Discussion 4 04-18-2006 11:32 PM
Newbie to G-Code maxxgraphix General CNC (Mill and Lathe) Control Software (NC) 2 03-03-2005 10:37 AM
