Old 08-24-2009, 06:26 AM
mcmachining is on a distinguished road
Resetting Machine Zero
We recently had our Z axis encoder rebuilt on our Miyano TSV-C37 which uses a Yasnac i80M controller. Does anyone know how I would go about resetting machine zero for the Z axis? Since we reinstalled the motor and encoder, it's way off. Specific or generic advice are both welcome.
Thanks in advance.
Old 08-24-2009, 06:44 AM
Karl_T's Avatar
Karl_T is on a distinguished road
Generic-
machines home by finding a home limit switch. Then switching to look for an index mark on the encoder. If you're off more than one screw revolution, look to the switch. Less than 1, rotate the encoder by lossening the coupler connection.
Karl
Old 08-24-2009, 06:57 AM
stevo1 is on a distinguished road
Originally Posted by Karl_T View Post
Generic-
Karl
That will get you close. Is it then up to the gridshift parameters to fine tune the position?
Stevo
Old 08-24-2009, 10:14 AM
Thanks for the help. I got it sorted out.
Old 08-24-2009, 10:38 AM
Share the info. What did you have to do to fix it? This will help if someone else has the same issue and comes across this thread during a search.
Stevo
SL 15 Parameter resetting MILLMANM Mori lathes 2 10-08-2008 10:01 AM
Resetting X0 Y0 Z0. Witsenburg Mach Software (ArtSoft software) 2 06-05-2007 09:39 AM
Mach keeps resetting Moondog Machines running Mach Software 7 08-15-2006 07:57 PM
Zero location resetting mid-run esmiller Machines running Mach Software 5 03-03-2006 02:00 PM
resetting fields hogman GibbsCAM 4 05-05-2005 08:22 PM
