Old 08-16-2009, 09:37 PM
woffler is on a distinguished road
Red face re repeating a program in mach 3
Hi every one i need some help with a little program in a drilling cycle i need two drill two different size holes in a part .I can get the part program from my cam program however I'm not sure how to once it runs through the first part.
I need it to go up one inch and stop turn of coolant spindle and wait for a cycle start in mach 3 controller and then repeat after i change the part. If some one could give me a little advise i sure would appreciate it .
Old 08-16-2009, 09:52 PM
ger21's Avatar
Assuming your in G90 mode, at the end of your g-code, add the following:
G91
G1 Z1
G90
M9
M30
Old 08-16-2009, 10:02 PM
Thanks for the help i was lost it should be in g90 ill double check .Thank You so much for your kind help.
Need Help!- mach 2 program scale vicsrc Mach Software (ArtSoft software) 4 12-16-2008 12:39 PM
Mach won't complete program ??? SScnc Mach Mill 5 08-15-2008 04:56 PM
How to program in Mach turn ? JDsto Mach Software (ArtSoft software) 4 11-29-2007 01:39 PM
Mach won't run my complete program. Green0 Machines running Mach Software 9 07-30-2007 02:41 PM
Mach 2 Program Question? qsacracer Mach Software (ArtSoft software) 7 11-17-2004 10:39 AM
