Old 02-26-2005, 09:09 PM
joe1970 is on a distinguished road
Exclamation fanuc o-t feed rate help
Hello fellas,
Iam new to the site and love it...... I recently bought a tong-tai lathe (hatachi-seki off chute) at a bargin basement price. It did not include any manuals. I am having a problem with feed I want to use the standard of inches per rev. but it will only feed in inches per min. even when I use a g99 code. I tried absoulte and incremental (G90 &G91) to see if this has any effect but no good. I can deal with the math to figure out the speeds and feeds but my other lathes will take a G99 and apply it proplerly. I am wondering if anyone out there knows of a parameter setting ?? am missing to something to get this to work properly? I have ran and programed fanuc for years and never ran into this problem maybe someone out there can share some of there wisdom with me??? thank-you
Old 02-26-2005, 09:55 PM
Al_The_Man's Avatar
Does the spindle have an encoder? if not it won't have constant surface feed.
Al
Old 02-27-2005, 05:57 AM
Factory Guy is on a distinguished road
If it has a spindle encoder try G95. Are you trying to use css or just inches per rev? I work mostly with 15, 16, 18, and 21 Fanucs, but I might have some 0-T manuals at work. I'll look Monday.
Old 02-27-2005, 09:51 AM
the spindle does have an encoder. I tried the G95 contol says the code is invalid.I always use css (unless I am threading or grooving) I think just a G-code list for the O-T control would help if anyone has one there has to be something simple I am missing I always program with a G90,G99 and G96
Old 02-27-2005, 12:27 PM
CAMCRASH is on a distinguished road
I program for a 0T at work
I will copy a G-Code sheet and will try to post it here
The Machine I prigram for is also a Tong-Tai machine
It is a Galaxy version unsure of the modle #
I will also try to look at the parameters and see which one controls the feeds
Tong Tai is great for forgeting books with there machines
The company I work for has one mill and one lathe
The mill came with a operators manual but no parts manual
The lathe came with a parts manual but no operators manual
Neither came with fanuc manuals which is not a big deal but when you are missing multiple it realy sucks to trouble shoot machines
Old 02-27-2005, 01:42 PM
that would be great camcrash sounds like we have the same machines mine also is a galaxy.(1996)
Old 02-28-2005, 09:57 PM
MMT MMT is offline
MMT is on a distinguished road
Does anyone know what FANUC stands for?
F riggin
A merican
N o
U nderstand
C hinese
Old 03-02-2005, 10:34 PM
joe I have not forgot this week started with a lot of fires I have been trying to put out I will try to get this info ASAP
Sorry,
Old 03-03-2005, 08:39 PM
Joe1970,
I sent you an email, but I might be able to post them here. Codes are for a 0T and 0M.
Hope this helps, Daryl
Old 03-03-2005, 08:40 PM
I brought the books home if you need more info.
  #11   Ban this user!
Old 03-03-2005, 09:13 PM
thank alot daryl i sent e-mails to the shop and see if they will help I am getting sick of converting fpm to fpr I do about 10 set-ups and programs a day all small runs and this is costing me time and money so your help is greatly appreciated this one has got me perplexed I thought I had seen it all but buy used equipment and live and learn...
  #12   Ban this user!
Old 08-29-2009, 12:15 AM
A L A L is offline
A L is on a distinguished road
Can i ask anyone,
When you do G95 for the first time, say with a G01, then type in your XYZ and your Feedrate, for the first time in your code, is that the only time you'll need to use G95?
Or do you need to specify mm/rev (G95) every time that your cutting?
This is for FANUC 6MB controller system...(i don't have access to a machine, its just for a university assignment)...
Need Bridgeport EZ-Track G-Codes to build post soweebee Bridgeport and Hardinge Mills 13 01-28-2006 02:10 AM
C & Z Feed rate rfstar G-Code Programing 7 06-22-2005 01:38 AM
Advice needed for Mill Feed Rate raytor Benchtop Machines 4 03-25-2005 02:11 PM
Feed rate question studysession General Metal Working Machines 6 10-30-2004 02:00 PM
How can I up my feed rate ? ynneb DIY-CNC Router Table Machines 7 07-12-2004 10:40 PM
