  #13   Ban this user!
Old 08-29-2009, 10:18 AM
dcoupar's Avatar
Originally Posted by A L View Post
Can i ask anyone,
When you do G95 for the first time, say with a G01, then type in your XYZ and your Feedrate, for the first time in your code, is that the only time you'll need to use G95?
Or do you need to specify mm/rev (G95) every time that your cutting?
This is for FANUC 6MB controller system...(i don't have access to a machine, its just for a university assignment)...
G94 and G95 are "modal", so when you program G95, it puts the control in feed-per-revolution mode, and it remains that way until it reads a G94. So if you always program in G95, put one in the beginning of the program and it will stay active for the entire program.
  #14   Ban this user!
Old 08-29-2009, 10:23 AM
beege's Avatar
beege is on a distinguished road
Also, the default turn-on mode is set by parameter, so you may "turn on" in G95 or in G94 (on my lathe its G98/G99)
  #15   Ban this user!
Old 08-29-2009, 10:29 AM
dcoupar's Avatar
Originally Posted by joe1970 View Post
the spindle does have an encoder. I tried the G95 contol says the code is invalid.I always use css (unless I am threading or grooving) I think just a G-code list for the O-T control would help if anyone has one there has to be something simple I am missing I always program with a G90,G99 and G96
Check parameter 007 bit 5. If it is 0, your control is set for "Standard G Codes", which uses G98 and G99 for FPM and FPR. If it's 1, the control will use "Special G Codes" which uses G94 and G95.
  #16   Ban this user!
Old 08-29-2009, 10:32 AM
dcoupar's Avatar
Parameter 007 bit 2 selects which code G94 (G98) or G95 (G99) is active at power up.
  #17   Ban this user!
Old 08-29-2009, 10:34 AM
beege's Avatar
Thanks for the info dcoupar!
  #18   Ban this user!
Old 08-29-2009, 11:49 AM
dcoupar's Avatar
Not a problem. That's why we all hang out here!
Need Bridgeport EZ-Track G-Codes to build post soweebee Bridgeport and Hardinge Mills 13 01-28-2006 01:10 AM
C & Z Feed rate rfstar G-Code Programing 7 06-22-2005 12:38 AM
Advice needed for Mill Feed Rate raytor Benchtop Machines 4 03-25-2005 01:11 PM
Feed rate question studysession General Metal Working Machines 6 10-30-2004 01:00 PM
How can I up my feed rate ? ynneb DIY-CNC Router Table Machines 7 07-12-2004 09:40 PM
