Old 07-22-2009, 12:05 PM
mcmachining is on a distinguished road
Soliciting Haas Macro Advice
Hello all,
I have another situation I need help with--this one is not so critical, though.
The following concerns a Haas TM-1.
I have no experience writing macros, but I'd like to have an alarm go off whenever the machine's M30 counter hits a certain number, then zero out the M30 counter.
I'm aware that Haas controllers have a function for tool life where you can set an alarm threshold that goes off after a certain amount of tool changes, and that is exactly what I'm looking to do, but this routine doesn't require a tool change. Rather than writing a macro, is there a parameter to advance the tool usage counter when a tool is called, but not actually changed?
Also, as a bonus question, I was wondering if there is a way to sound an audible alarm to warn an operator of the forthcoming end of a program, or if I have to install an alarm and connect it to one of the miscellaneous M code relays.
Thanks again,
MC
Old 07-23-2009, 07:29 AM
chucker's Avatar
chucker is on a distinguished road
(TOOL LIFE ALARM) Marco
Just put this in your program after the tool runs each time You can change the # numbers to use it on more than one tool #632 would be what you set for your limit of how many parts to run on the tool. I set this up for our mill
the #1129,#1139 may be different on your machine try it in MDI the rest should work ok when the alarm is set off it will put a masage on the screen and put the machine in Feed hold
O1234
PART PROGRAM HERE
#631= #631 + 1 (COUNTS 1 TIME EACH TOOL IS RAN)
(TOOL LIFE ALARM)
IF [ #631 GE #632 ] GOTO1000
IF [ #631 LT #632 ] GOTO1001
N1000
#631= 0 (SET COUNTER TO ZERO)
#1129= 1 (RED LITE ON)
#1139= 1 (BUZZER ON)
(ALARM STATEMENT)
#3006= 1 (CHANGE 3/4 MILL)
#1139= 0 (BUZZER ON OFF)
#1129= 0 (RED LITE OFF)
N1001
NEXT TOOL PART PROGRAM HERE
Old 07-23-2009, 09:57 AM
Excellent. Thank you very much. I'll plug that in when I get a chance and test it out.
Old 07-27-2009, 05:36 PM
I'm looking to start incorporating more macros into my programming. Does anyone know where I would go to find a comprehensive list of macro variables? For example, how did you know that #1139 controls the buzzer, chucker?
I program for both a Haas TM-1 and a Miyano with a Yasnac i-80 controller. Google isn't very helpful in this department. Is it something I'll have to go to the manufacturer for?
Old 07-28-2009, 12:07 PM
chucker's Avatar
Fanuc%20Variables(1).xls
Things like #1139 can be found in your mantaince manaul the are called descrett inputs and outputs
Problem- Soliciting comments Carlton Jenkins Okuma 5 07-14-2008 12:06 PM
Need Help!- Macro Advice - Customising Mach3 UKRobotics Mach Wizards, Macros, & Addons 2 06-08-2008 06:09 PM
Advice on a Haas VF0 mbpp Haas Mills 1 08-21-2007 05:30 PM
Haas VF3 Y cable fault error - advice? JHR1 Haas Mills 2 05-27-2006 08:05 PM
Haas Vf-2,macro For Tool Life Tulak Haas Mills 0 10-22-2004 09:06 AM
