Old 07-16-2009, 04:44 PM
ikneb is on a distinguished road
machining elliptical punch and die
I need to make an elliptical punch and die, and I have not done much 3D machining.First can you comp a ballmill in Y and Z the way you would in X and Y
a regular endmill ?Second if you cant use cutter comp how do you write the comp into the toolpath for the die? For the punch I am thinking that I could program the ellipse wider by the cutter diameter.For the die I'm not sure what I should comp and where.Mind I don't have CAD CAM software and I am using a FANUC Oi-MC control
Old 07-16-2009, 06:37 PM
Get lucky's Avatar
Get lucky is on a distinguished road
The only way that you could comp it is useing scaleing feater of the control there are sevral post on here about it in resent days.
Kyle
http://http://www.cnczone.com/forums...ad.php?t=84627
You must remember that 99% of my posts are Bullchit!
Old 07-16-2009, 06:49 PM
I'm having trouble with that link
Old 07-17-2009, 08:09 AM
Get lucky's Avatar
Here try it again.
Kyle
http://cnczone.com/forums/showthread.php?t=84627
Punch?? or What?? ShayArnett General Metalwork Discussion 8 03-19-2010 09:28 PM
Punch Presses David Cockburn General Metal Working Machines 4 10-11-2007 11:00 AM
cnc punch newrock G-Code Programing 0 08-22-2007 09:17 AM
RFQ punch holer fastolds Employment Opportunity 2 11-29-2005 04:45 PM
