Old 07-14-2009, 10:29 AM
cSpampinato is on a distinguished road
Manual tool comp on partial radius (Lathe)
I've been trying to figure out on my own how to manually calculate the tool nose compensation on a partial radius for a while now and i just can't seem to get it. However, I can get it right when i use the formula for tool comp on a straight line. So basically my question is: Is the formula for figuring out tool nose radius compensation the same for angles as well as for radii?
Here are the formulas i am using:
z axis comp= nose radius-(nose radius x tan(angle [divided by] 2))
x axis comp= 2 x [nose radius-(nose radius x tan(45- (angle [divided by] 2))]
Old 07-14-2009, 01:51 PM
encarlisle is on a distinguished road
from the theoretical sharp corner trig out start finish points of the arc + tnr for .1 arc and .0312 tnr .1312 arc then program r value .1312 hope this helps.
tool nose radius comp joe1970 G-Code Programing 8 02-24-2010 09:43 PM
Manual tool comp on partial radius (Lathe) cSpampinato Mechanical Calculations/Engineering Design 5 07-15-2009 08:02 PM
Need Help!- Manual tool comp on partial radius (Lathe) cSpampinato General Metalwork Discussion 0 07-13-2009 07:53 AM
Help with tool nose radius comp mcash3000 General CNC (Mill and Lathe) Control Software (NC) 6 05-09-2008 08:25 AM
Tool radius comp cijunet Mastercam 5 12-20-2007 03:27 PM
