Old 07-12-2009, 12:26 PM
George is on a distinguished road
Acad to Gcode
Almost finished my flatbed router, I use Acad and Mach3. Can anyone suggest an uncrippled version of DXF to Gcode conversion programme ?
I'd rather have a time expired demo prog rather than one that chops half the code out.
Many thanks
George
Old 07-12-2009, 01:24 PM
ger21's Avatar
Free macro that converts circles and polylines into g-code. Works in 2002 and newer.
http://home.comcast.net/~cncwoodwork.../ac2gcv043.zip
More info here.
http://www.cnczone.com/forums/showthread.php?t=8226
Old 07-12-2009, 01:41 PM
ger21's Avatar
If you want a commercial package, look at Vectric's Cut2D or SheetCAM.
CamBam has a free version.
http://www.cambam.co.uk/
G Simple is free,
http://www.gsimple.eu/
Old 07-12-2009, 02:33 PM
No arc
Hi Gery,
Thanks,
Loaded your routine into ACAD2008. Worked first time, exported a small cnc file some lines and circles but my arcs were missing ?
I'll have another try.
George
Old 07-12-2009, 04:11 PM
ger21's Avatar
Polylines and Circles only. If you have arcs, join them into a polyline, or convert them with the PEDIT command.
Old 07-13-2009, 04:43 AM
Pedit
Thanks gerry,
If I'd read the first paragraph of your instruction I'd have known this :-)
Your routine woks just fine,
Thanks you,
I will investigate others but yours will get me going.
George
ACAD formula help please ImanCarrot Autodesk Software (Autocad, Inventor etc) 1 04-06-2011 08:51 PM
ACAD issue butterRPG Joes CNC Model 2006 7 12-27-2007 06:11 PM
Acad 07 to mastercamX Demon440 Mastercam 3 01-04-2007 09:04 AM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 12:46 PM
how do i get my cnc to cut my acad dwg? ljoe1969 Autodesk Software (Autocad, Inventor etc) 6 11-05-2003 10:05 AM
