| G-Code Programing Discuss G-code programing and problems here! |
| Write a program for the circle using the center of the ciorcle as your work zero location. Make this a sub program. Write a program to call this program after using a G52 command to place a local work coordinate at the circle center. For instance if your main work zero is G54 and your circles are at X4. Y0., X2 Y0., X0. Y0., X-2. Y0., X-4. Y0. your program structure would be something like this. O00001 (circle main program) stuff G52 X4. Y0. M98 O00002 G52 X2. Y0. M98 O00002 G52 X0. Y0. M98 O00002 G52 X-2. Y0. M98 O00002 G52 X-4. Y0. M98 O00002 stuff M30 O00002 (Circle cutting program) All the commands to cut the circle using X0. Y0. as the center of the circle M99
| Appreciate the help Geoff unfortunately I couldn't get it to work. Here's what I have for the first circle:- N10 G71 LX=1980 LY+760 LZ=37 HC1 Z=PRK N12 BOT=280 LFT=280 RAD=150 N20 X=BOT Y=LFT+(RAD-8) Z=PRK PRF=LPZ/2 F3 TP2 L=PON N30 G2 X=BOT Y=LFT+(RAD-8) J+LFT I=PON N40 L=PSU N50 X=BOT Y=LFT+(RAD-8) Z=PRK PRF=LPZ F3 TP2 L=PON N60 G2 X=BOT Y=LFT+(RAD-8) J+LFT I=PON N70 L=PSU N80 X=BOT Y=LFT+(RAD+4) Z=PRK PRF=-14 F3 TP2 L=PON N90 G2 X=BOT Y=LFT+(RAD+4) J+LFT I=PON N100 L=POFF N110 X=PRK Y=PRK % I am using a Biesse Rover 321 R ATC with a CNI NC 481 controller. |
Those Italian machines that have their own version of G-code. I owned one briefly in partnership with a friend who is a cabinet maker; after six months I sold my share to him because programming the Biesse was so different to metal working machines it drove me up the wall.
Thanks Geoff. Yes its driving me up the wall with no manual and trying to decipher the programs in the memory. |
| What did you use to get that first program? Did you hand code it? Does Biesse have a G or M code to offset the origin?
The code was modified from a program already in the machine. The previous operator who left before I started working for the company 4 weeks ago used to hand code it. At the moment I couldn't tell you how to offset the origin. I have learnt so far that you cant create an arc by simply altering the I and J. |
| damn thats a lot of code for a circle!!!! i have a 321r atc with 481 controller. in uk the best circles are using circle centre at zero, zero if cutting from inside circle make a segment from centre to circumference, arc to end point centres known eg i0 j0 then lead back out to centre. depending on cutter used you may wish to ramp the cutter down on lead in use xo=50 yo=50 (letter ow not zero) to place centre of circle at 50, 50 depending if your cutting on line g40, left of line or right of line etc you must add a lead in and lead out. see my pool table video on you tube biessebod. i can send you the code for it if you like. order yourself an expensive manual and fault code book from biesse uk approx £125 BUT TOTALLY INVALUABLE. |
| your code is written to offset the tool radius... presumably for 16mm cutter? the best way to do this is set tool table up correctly with exact tool diameter ie 15.95mm etc which can be easily changed at each resharpening then use g41 or g42 to offset the tool. ring me if you wish and il explain it. 07866631400 where are you based? |
#10
| this is a sample program calling a external sub routine for a hole at different positions. i will paste one of a program with internal sub routine if i can find one! N19 L=G7 QX=1715 QY=-2 PRF=LPZ+6 YF=930 F=5 QQN=2 N20 L=GC1 UT=1 N30 X20 Y-10 Z=PRK PRF=LPZ+4 F6 G41 TP1 L=PON N39 G1 X79 N40 G1 Y16 N50 G1 X16 BR10 N60 G1 Y79 N70 G1 X0 N90 G1 Y=LPY-79 N99 G1 X16 N99 G1 Y=LPY-16 BR10 N99 G1 X79 N99 G1 Y=LPY N99 G1 X=LPX-79 N99 G1 Y=LPY-16 N99 G1 X=LPX-16 BR10 N99 G1 Y=LPY-79 N99 G1 X=LPX N99 G1 Y79 N99 G1 X=LPX-16 N99 G1 Y16 BR10 N99 G1 X=LPX-79 N99 G1 Y0 N99 G1 X20 N99 G1 X-20 Y-10 G40 N100 L=PSU N110 XO=LPX/2-750 YO125 L=H112 N120 XO=LPX/2-275 YO85 L=H112 N130 XO=LPX/2+275 YO85 L=H112 N140 XO=LPX/2+750 YO125 L=H112 N210 X=LPX/2+620 Y109 Z=PRK PRF=LPZ+4 G40 TP1 L=PON N219 G1 Y115 N220 L=PSU N230 X=LPX/2+410 Y109 Z=PRK PRF=LPZ+4 G40 TP1 L=PON N239 G1 Y115 N240 L=PSU N210 X=LPX/2-410 Y109 Z=PRK PRF=LPZ+4 G40 TP1 L=PON N219 G1 Y115 N220 L=PSU N230 X=LPX/2-620 Y109 Z=PRK PRF=LPZ+4 G40 TP1 L=PON N239 G1 Y115 N240 L=PSU N277 X=LPX/2-300 Y=LPY/2-219 Z=PRK PRF=3 F10 G41 TP1 L=PON N277 G1 X=LPX/2-300 Y=LPY/2-209.5 N277 G1 X=LPX/2-500 N277 G1 Y=LPY/2-229.5 N277 G1 X=LPX/2-300 N277 G1 X=LPX/2-350 Y=LPY/2-219 G40 N277 L=PSU N277 X=LPX/2+300 Y=LPY/2-219 Z=PRK PRF=3 F10 G42 TP1 L=PON N277 G1 X=LPX/2+300 Y=LPY/2-209.5 N277 G1 X=LPX/2+500 N277 G1 Y=LPY/2-229.5 N277 G1 X=LPX/2+300 N277 G1 X=LPX/2+350 Y=LPY/2-219 G40 N277 L=PSU N210 X=LPX/2+620 Y=LPY-109 Z=PRK PRF=LPZ+4 G40 TP1 L=PON N219 G1 Y=LPY-115 N220 L=PSU N230 X=LPX/2+410 Y=LPY-109 Z=PRK PRF=LPZ+4 G40 TP1 L=PON N239 G1 Y=LPY-115 N240 L=PSU N210 X=LPX/2-410 Y=LPY-109 Z=PRK PRF=LPZ+4 G40 TP1 L=PON N219 G1 Y=LPY-115 N220 L=PSU N230 X=LPX/2-620 Y=LPY-109 Z=PRK PRF=LPZ+4 G40 TP1 L=PON N239 G1 Y=LPY-115 N240 L=PSU N277 X=LPX/2-300 Y=LPY/2+219 Z=PRK PRF=3 F10 G42 TP1 L=PON N277 G1 X=LPX/2-300 Y=LPY/2+209.5 N277 G1 X=LPX/2-500 N277 G1 Y=LPY/2+229.5 N277 G1 X=LPX/2-300 N277 G1 X=LPX/2-350 Y=LPY/2+219 G40 N277 L=PSU N277 X=LPX/2+300 Y=LPY/2+219 Z=PRK PRF=3 F10 G41 TP1 L=PON N277 G1 X=LPX/2+300 Y=LPY/2+209.5 N277 G1 X=LPX/2+500 N277 G1 Y=LPY/2+229.5 N277 G1 X=LPX/2+300 N277 G1 X=LPX/2+350 Y=LPY/2+219 G40 N277 L=PSU N278 XO=LPX/2+750 YO=LPY-125 L=H112 N278 XO=LPX/2+275 YO=LPY-85 L=H112 N278 XO=LPX/2-275 YO=LPY-85 L=H112 N278 XO=LPX/2-750 YO=LPY-125 L=H112 N278 L=POFF N278 L=GC1 UT=5 N279 XO=LPX/2-750 YO125 L=H112C N279 XO=LPX/2-275 YO85 L=H112C N279 XO=LPX/2+275 YO85 L=H112C N279 XO=LPX/2+750 YO125 L=H112C N279 XO=LPX/2+750 YO=LPY-125 L=H112C N279 XO=LPX/2+275 YO=LPY-85 L=H112C N279 XO=LPX/2-275 YO=LPY-85 L=H112C N279 XO=LPX/2-750 YO=LPY-125 L=H112C N279 L=POFF N280 X=PRK Y=PRK % |
#11
this one calls internal sub routines. a very clever program i wrote if i say it myself. it cuts internal circles out around a radius calculated from parameters input at n30 . took me a night to think how to do it and a day to code it! but its cut hundreds of parts since and is simple to change it is set to centre the entire piece at x350 y650. after the tool change to ut5 it does an outer circle with lead in and out. basically it cuts a large circle with a "bolt hole circle"of 23mm diameter holes inside the radius of the outer circle hope these are of use to you! N20 L=GC1 UT=1 N30 MC=380 CD=290 HD=23 NH=10 DA=360/NH HP=5 ;MC=OUTER D CD=HOLE CIRCLE D HD=HOLE D NH=NUM HOLES HP=HOLE DEPTH N40 DD=0 AN=0 ;N50 XO=MC/2+5+350 YO=MC/2+5+700 N50 XO=350 YO=650 ZO=-7 :1 N60 JM(DD=NH):2 N70 X0 Y0 Z=PRK PRF=-10 F10 G40 TP1 L=PON N80 G1 BL=CD/2 BA=AN N85 G1 Z=-LPZ+HP N90 G1 BL=HD/2 BA90 F2 N100 XI.01 R=HD/2 G5 RP=4 ZI=LPZ/4+0.6 N110 G1 BL=HD/2 BA270 Z=-LPZ-10 F10 N120 G1 X0 Y0 G40 N130 L=PSU N140 DD=DD+1 AN=DA+AN N150 JM:1 :2 N160 X0 Y=-MC/2-20 Z=PRK PRF=3 F5 G42 TP1 L=PON N170 G1 Y=-MC/2 N180 G2 X0 Y=-MC/2 I0 J0 RP=4 ZI=LPZ/4+1 N210 G1 Y=-MC/2-20 G40 ;N220 L=PSU ;N230 X0 Y0 Z=PRK PRF=2 F1 G40 TP1 L=PON N240 L=POFF N160 L=GC1 UT=5 N160 X0 Y=-MC/2-20 Z=PRK PRF=LPZ/2+1 F5 G41 TP1 L=PON N170 G1 Y=-MC/2+.5 N180 X0 Y=-MC/2+.5 I0 J0 G2 N210 G1 Y=-MC/2-20 G40 N240 L=POFF N250 Y=PRK % |
#12
| Thanks for the reply Battwell. I have just emigrated to NZ from the UK. At present I am only getting 1/2 hr per week on the WWW at the local library. I will try your code next week when my stuff arrives. Yes I aggree the G41 G42 codes would be better for the offsets but I just quicky stuck the program together using a program already in their called 'any hole'. Couple of questions is it possible to type the code on PC to floppy an I get a persistant X59 error even though a tool is in? The machine is somewhat lacking in maintenace but I hope to cure that. Can I also connect a PC to the CNI unit for more specialist tasks like sign making. Using MACH and Vectric on my own machine. |
| Problem- Axis not repeating | Aircraftman | Mazak, Mitsubishi, Mazatrol | 6 | 07-31-2009 02:16 AM |
| ALARM 401 REPEATING | CHANDRU | Fanuc | 4 | 07-13-2009 09:24 AM |
| Need Help!- circles arent circles | xlr8r | DynaTorch | 3 | 01-18-2009 11:26 AM |
| Repeating a Subroutine. | Mike Mattera | G-Code Programing | 6 | 05-18-2008 04:01 PM |
| Repeating issue | scorchtool | Milltronics | 16 | 01-19-2008 07:26 AM |
