Old 07-09-2009, 04:51 PM
BoKo is on a distinguished road
Question Mach BNE 51S - Fanuc 18-T - work zero offset???
Hi! I work on the mach BNE 51S, Fanuc 18-T and I have a problem with Work Zero Offset. Machine doesn`t read G54, G55 ..... G59 (alarm 010 IMPROPER G-CODE). I think I need activating some parameter (parameters). Does anyone have the parameters book of Fanuc 18-T?
BoKo
Old 07-10-2009, 06:40 AM
stevo1 is on a distinguished road
Do you have the workoffset page on the control? You can view the G54-G59 and set them? Improper G-code usually means that the option is not installed on the control. However if it is not installed I would think you could not view or set them.
Send me a PM with your email address and I will send the manual.
Stevo
Old 07-10-2009, 04:08 PM
Yes, I do. I see screen with workoffset, I changed values on the workoffset G55, G56 and no problem but machine didn`t see G54 - G59 from the program.
It is possible becouse this is 15 years old machine but I want to check it!
Check PM please!
BoKo
Old 07-13-2009, 07:30 AM
BoKo,
I got your email. I will send you the manual later today. I don't have my flashdrive with me at the moment and that is were I have them.
You say that the machine does not read G54-G59. So you always get the "IMPROPER G-CODE" everytime you program a G54-G59?? It is weird that you can view and change them if the option is not activated. If you do an MDI G55; insert then cycle start....the machine alarms out??
Stevo
Old 07-21-2009, 09:16 PM
Stevo1 - thanks for manual. Last week I didn`t work and I didn`t try change anything. Yesterday I checked and .....
I have same alarm!!!!
Yesterday I changed the parameters, however the machine's alarm continues to alert me with <Improper G-code>. I believe there is a need to change the parameters in the following window: <Keep Relay>. However I don't have any information/guidelines on this topic. I was wondering if you might have something like that?
BoKo
Name:	Keep Relay.jpg‎
Old 07-27-2009, 07:42 AM
BoKo,
There will not be many guidelines to the keeprelays in the Fanuc book as these are usually setup by the MTB. If you have the MTB manual it should give some insight as to what the settings of these are. These however will not help divert this alarm.
As I stated before an improper G-code alarm usually means that that option is not activated on your control. I will send you a PM to find out if you actually have this option activated.
Stevo
Mach 3 work offset retention. Geoff86 Machines running Mach Software 9 01-30-2010 02:03 PM
work offset page, puma 250, fanuc 18T cuz1007 Daewoo/Doosan 1 03-29-2009 12:32 PM
Work Offset Question Cartierusm Mach Software (ArtSoft software) 17 11-29-2007 03:50 PM
Running one work offset. ltmquik Haas Mills 20 09-07-2007 01:02 PM
work offset in fanuc 6m b- help rags Fanuc 14 08-03-2006 09:39 PM
