| G-Code Programing Discuss G-code programing and problems here! |
| LinkBack | Thread Tools | Search this Thread | Display Modes |
I am trying to tap a left hand 7/16-20 tap in kia turn21 with a fanuc oi-TB This is what I do for a R.H. tap (7/16-20 SPIRAL TAP R.H.) G97S200M3 G0X0Z.2T1010 M129S200 G84Z-1.75F.05 G80M9 M128 G28U0W0T1000 This is what I tried for a L.H. tap and did not work G0T1000M8 (5/16-18 CUT TAP L.H.) G97S200M4 G0X0Z.2T1010 M129S200 G74Z-1.5F.05 G80M9 M128 G28U0W0T1000 Any input would be appreciated Kyle
__________________ You must remember that 99% of my posts are Bullchit! |
| Begee, G74 just seemed logical to me never had to program for a L.H. tap before so I figured I would give it a try. G74 is a milling L.H. tapping cycle maz43, No TC holder not sure I understand what a TC holder is I think you are talking about a floating head holder. jawbreaker38, Yes this is on a lathe, I was reading in the fanuc book and it says that I should be using a G84 just change from a M3 to a M4 didn't work toolsur, were is your math from 1/20=.05, 1/18=.055. I'm not sure I follow what you are trying to get at. Here is my problem in more detail G0T1000M8 (change turret to station 10) (7/16-20 CUT TAP L.H.) G97S200M4 (spindle starts in revers) G0X0Z.2T1010 (turret positions in front of the part) M129S200 (spindle stops ) G84Z-1.5F.05 (spindle starts in foreword and turret feed Z- and then spindle reverses and turret feed Z+ back to start position) G80M9 (cancel G84) M128 (cancel M129) G28U0W0T1000 (send turret to home position) The fact that on the G84 line it doesn't start as a M4 doesn't work for me and I'm not sure how to make it start as a m4 Thank you kyle
| Ok, I guess I'm not getting the M129 command, for rigid tapping I assume? I would've thought that it was M29. I'd go with the G32 method, and I'm sure you will have no problem in rigid mode if done correctly. I'd do it like this- G00 G18 G99 T202 S500 M04 X0. Z.1 M08 G32 E.0556 Z-1. M05 (use E or F on this line and put the M05 on this line) G32 Z.1 M03 G00 Z1. M09 G28 U0. W0. M05 M01 The M05 command will be read last, so it will be performed when the tool has reached it's depth. I neglected to pay attention to the pitch of our thread, but this is just an example anyway. Hope this helps. |
#11
| My Haas lathe uses G84 Forward Tapping Cycle and G184 Reverse Tapping Cycle. My old Fanuc controlled mill used G84 Forward and G74 Reverse. I would bet that there is a similar Gcode in there to do what you need. Good luck and post your findings here as I'm sure they would be usefull down the road. |
#12
| Proprocess, M129-200 resulted in a illegal us of negative sign Jawbreaker, The G32 worked but snapped the tap in the bottom (bound up chips) of the hole so I tried to run the tap half way in and then to full depth but got a miss match thread. When I ran the the other side witch was 7/16-20 R.H. I had allot higher quality tap available to me, nobody makes a good quality tap in a L.H. that will tap to full depth. begee, G84.1 resulted in illegal G-code The M129, This is what I have have found out on the M129. I was not sure what it was for myself until I was looking threw the fanuc book and I found the section 4.22 (parameters of rigid tapping ) in the the parameter manual. Parameter #5210 (Rigid tapping mode specification M code) [data type] byte [valid data rang] 0 to 255 This parameter sets an m code that specifies the rigid tapping mode. To set the M code larger then 255, set it to parameter No.5212 NOTE: 1 The M code is judged to be 29 (M29) when "0" is set. 2 To use an M code whose number is greater than 255 specify the code number with parameter No.5212 Parameter #5212 (M code specifies a rigid tapping mode) [Data type] 2-word [Unit of data] Integer [Valid data range] 0 to 65535 This parameter sets an m code that specifies the rigid tapping mode. The M code that specifies the rigid tapping mode is usually set by parameter 5210. To use an M code whose number is greater then 255 specify the code number with parameter 5212. NOTE: If the setting of this parameter is 0, the M code specifying the rigid tapping mode is determined by the setting of parameter 5210. Otherwise, it is determined by setting of parameter 5212. The setting of parameter 5212 must always be within the above valid range. parameter #5210 is set to 129 parameter #5212 is set to 0 So if what I read there and copied to this thread means the same thing to you as it did to me, well that is were the M129 came from as for the M128 to cancel have not found that yet. Thank you everybody this is a pain in the @ss Kyle
| left hand 3-48? | skmetal7 | Mechanical Calculations/Engineering Design | 0 | 05-05-2009 01:49 AM |
| Need Help!- Rigid tapping Left hand | DocHod | Fanuc | 9 | 06-19-2008 11:54 PM |
| Why do you use your left hand | ImanCarrot | General Metalwork Discussion | 24 | 10-15-2007 06:14 AM |
| Left hand cutters | DAB_Design | General Metalwork Discussion | 6 | 11-03-2004 09:23 AM |
| coverting from Right-hand to left-hand coordinate system | eltonr | General CAM Discussion | 6 | 10-14-2004 08:40 PM |
