Old 07-02-2009, 11:56 AM
Ecmdrw5 is on a distinguished road
Exclamation Spindle Synchronization M480???
We are running this on a Mori NL-2000 with twin spindles and live tooling. We are trying to mill a flat on 2 sides across a 19" piece of material when it's supported in both spindles. We want the spindle to index 180 degrees without having to do our current method. Right now we just use a M211 to unclamp spindle 2,rotate spindle 1, and then M210 to clamp spindle 2. The Mori book talks about a M480 which will make spindle 2 follow spindle 1 so we don't have to unclamp spindle 2 but it gives us an error. It says (no O program number o o ). That doesn't make any sense to me. If anyone has any ideas please share.
Old 07-02-2009, 12:29 PM
stevo1 is on a distinguished road
I don’t know much about the Mori’s and the twin spindles but I will give it a guess.
By the looks of the error it is trying to search for a program and cannot find it. Maybe this M480 is designed to call a subprogram to sync the 2 spindles but the program is not in memory and it cannot find it. I could be way off base as it does not make much sense to me either. I would think that if Mori designed a specific M-code to sync the spindles that they would use the ladder to do so and not a program.
Don’t know if that helped but that’s my .02c
Stevo
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
Need Help!- synchronization of 3 servo motor using interpolation eureka Servo Motors and Drives 0 11-11-2008 09:05 AM
phase synchronization? maximusek CNC Swiss Screw Machines 0 12-18-2007 06:39 AM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 02:49 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
