Old 02-14-2005, 09:27 PM
acseatsri is on a distinguished road
Work coordinate in canned cycle line
Can you use a G54 command in the same line as a canned cycle?
Example:
G43Z1.H1M8
G55 G82 G98 X2.536Y.155 Z-1.3 R-.95 P50 F10.
G56 G82 G98 X2.536Y.155 Z-1.3 R-.95 P50 F10.
Will this format work to drill the same hole in 2 work coordinate systems?
This is on a Fanuc 0M controller.
I'm at a new position and the existing programs seem to waste a lot of memory and space with extra lines of code
Old 02-14-2005, 10:11 PM
HuFlungDung's Avatar
Moderator
You can always go and try it (without tools or work in place). The control will likely alarm if it does not accept it. Otherwise, just call the work coordinate system on a solitary line before each G82.
Help teach G-code for rookie HighOctane G-Code Programing 16 03-16-2006 10:18 AM
Macro Work Coordinate firedog G-Code Programing 7 06-17-2005 01:03 PM
Haas G85 Boring Cycle (canned) DEAN Haas Mills 7 12-08-2003 11:12 AM
Tool tables Nimrod Mastercam 4 11-24-2003 03:31 PM
Post configuring (black art?) John F OneCNC 12 07-18-2003 02:26 PM
