Old 06-22-2009, 07:34 PM
Maxz is on a distinguished road
Helical cutting
I would like to make a hole 100 mm with 250 mm depth on 18M control. It is possible to do that by using helical method? (tool dia 60 mm)
I tried..
N001 G1 Z0 X20. Y0 F600
N002 G3 G17 X20. Y0 Z-250. K1.25 I0 J0 F200
N003 G1 X0 Y0
N004 G0 Z50.
It shown alarm ILLEGAL PLANT AXIS COMMAND
Please suggest what I did wrong. I already change parameter #9930 as 1100111
Thanks in advance
Maxz
Old 06-22-2009, 09:14 PM
Additional information,
I tried below with A2100 (Cincinnati) it can work smoothly
N002 G3 G17 X20. Y0 Z-250. F200 K1.25 I0 J0
N003 G1 X0 Y0
N004 G0 Z50.
Old 06-23-2009, 12:00 AM
HuFlungDung's Avatar
Moderator
I would question the arc center coordinates. If the arc centers are incremental, then I0J0 could not be correct for a 50mm radius.
If the arc centers are in absolute coordinates (on the Cinci) and the hole is centered on X0Y0, it could work.
Old 06-23-2009, 07:43 AM
dcoupar's Avatar
Try this:
N002 M98 P2001001(CALL SUB 200 TIMES)
N003 G1 G90 X0 Y0
N004 G0 Z50.
M30
O1001(SUB)
G3 G17 G91 Z-1.25 I-20. J0 F200
M99
Old 06-23-2009, 10:44 PM
Hi Dcoupar,
thank you for your advice. I will let you know the result after I try.
Maxz
Old 06-25-2009, 05:00 AM
Hi Dcoupar,
I have tried the suggestion. It worked so good. Thank you so much.
Maxz
Old 06-26-2009, 12:38 AM
davereagan is on a distinguished road
Did you do this from the solid? What style of facemill? 50 taper spindle? (That's a long hangout for a 40 taper)
Old 06-26-2009, 12:56 AM
I used 66 mm diameter with round insert. I have drill dia 40 mm at the center before helical cutting. I extend the holder with 60 mm capto (total length 290 mm)
My OKK machine is BT50 taper. I changed the depth (from 1.25) to 0.7 mm only. Spindle 1200 rpm with 800 table feed. Workpiece is S45C material.
Old 06-26-2009, 01:10 AM
That sounds like quite a rigid machine. So you are running 357 laps with .7mm lead? Is it just too loud/harsh sounding with 1.25mm lead? With 66mm cutter, your cutting path radius is 17mm, right? I calculate 106.76mm per revolution, so you would be running 7.5 laps per minute and 357 laps would take 48 minutes. Long time, but to have a 100mm hole 250mm long in medium carbon steel 48 minutes later would be nice.
Problem- FANUC 3M Helical cutting renato13 Fanuc 12 01-14-2010 12:53 PM
FANUC 3M Helical cutting renato13 Parametric Programing 1 01-26-2009 05:04 PM
Ideas upon Internal Helical groove cutting brianklein General Metalwork Discussion 26 01-11-2009 11:44 PM
G2/g3 Helical In Yz(g19) leggetmachine G-Code Programing 4 03-22-2006 10:48 PM
