| G-Code Programing Discuss G-code programing and problems here! |
Im trying to threadmill a 3/4 14 npt hole. Im using a Okk witha a mitsubishi meldas 5000c controler. The tec guy for the company we bought the theardmill gave us this code -d % N1G28 X Y Z N2G90G92X309949 Y61959 Z0 N198G90G40 N199G90G43G00 X8750 Y-20000 Z5000H23 N200G01 Z0 F220 N201S2726M03 N202M8 N203G91 G01 Z-4989 F220 N204G41 X1523 Y-1523 F76 H21 N205G17 G03 X1523 Y1523 Z0089 I0 J1523 F30 N206G03 X-3045 Y3051 Z0179 I-3051 J0 F43 N207G03 X-3057 Y-3051 Z0179 I0 J-3057 N208G03 X3057 Y-3062 Z0179 I3062 J0 N209G03 X3068 Y3062 Z0179 I0 J3068 N210G03 X-1534 Y1534 Z0089 I-1534 J0 F30 N211G01 G40 X-1534 Y-1534 F220 N212G00 Z4097 N213G90 G00 Z5000 N290G92Z0 N291G28XY N292M9 N293M30 % We've tryed several things to make it work but we keep comming up with program errors. Any help would be great. |
| Ugh. I hate code that doesn't have spaces and decimal points... Give this a try. % N1 G28 X Y Z N2 G90 G92 X30.9949 Y6.1959 Z0 N198 G90 G17 G40 N199 G90 G43 G00 X.8750 Y-2.0000 Z.5000 H23 N200 G01 Z0 F.0220 N201 S2726 M03 N202 M8 N203 G91 G01 Z-.4989 F.0220 N204 G41 X.1523 Y-.1523 F.0076 H21 N205 G03 X.1523 Y.1523 Z.0089 I0 J.1523 F.0030 N206 G03 X-.3046 Y.3052 Z.0179 I-.3052 J0 F.0043 N207 G03 X-.3058 Y-.3052 Z.0179 I0 J-.3058 N208 G03 X.3058 Y-.3064 Z.0179 I.3064 J0 N209 G03 X.3070 Y.3064 Z.0179 I0 J.3070 N210 G03 X-.1535 Y.1535 Z.0089 I-.1535 J0 F.0030 N211 G01 G40 X-.1535 Y-.1535 F.0220 N212 G00 Z.4095 N213 G90 G00 Z.5000 N290 G92 Z0 N291 G28 X Y N292 M9 N293 M30 %
__________________ Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers |
| Yes, Please. What error. Below is the code I chunked out with a free thread mill code chunker-outer from Seco. http://www.secotools.com/wps/portal/corp/Epi_510 May have to tweak the cutter-comp setting. It takes so little time with the Seco program, I have yet to put those beautiful thread-mill motion descriptions in the back of the Emuge threading books into machine macros. http://www.emuge.com/carbide_thread/ Look for the PDF files.... Brings a tear to my eye they are so pretty. Just watch out for the way calculators or CAD/CAM packages ask for the depth and use it. Some take a 0.5 inch depth and arc up from there. No sparks when they rapid in. Some take a 0.5 inch depth and start a quarter or so pitch deeper to give what they asked for - how deep do you want the thread. Watch your fingers ![]() % O0110 (This part-program was generated by the Thread Milling Wizard) (Material: Seco Group 20. Ni-. Co-. ferrous super-alloys. <30HRc.) (Thread milling: Right-hand internal 3/4 NPT x 14TPI - 0.4989 in deep.) (Component starting diameter: 0.9055 in x minimum depth of 0.522 in.) (Thread milling cutter: R396.19-2517.3S-4003-2A. Insert: 2 x R396.19-4003.0X14NPT F30M.) G20 G00 G90 G94 G40 G28 G91 Z0.0 G90 T23 M06 G54 S1226 M03 G00 X0.875 Y-2.0 G43 Z0.5 H23 M08 G00 Z-0.522 G01 G91 G41 X-0.1401 Y0.0002 D21 F2.8 G03 X0.3353 Y0.0 Z0.0214 I0.1677 J0.0 G03 X-0.0572 Y0.1381 Z0.0089 I-0.1953 J0.0 G03 X-0.1383 Y0.0573 Z0.0089 I-0.1383 J-0.1383 G03 X-0.1385 Y-0.0574 Z0.0089 I0.0 J-0.1959 G03 X-0.0575 Y-0.1387 Z0.0089 I0.1387 J-0.1387 G03 X0.0575 Y-0.1389 Z0.0089 I0.1964 J0.0 G03 X0.1391 Y-0.0576 Z0.0089 I0.1391 J0.1391 G03 X0.1393 Y0.0577 Z0.0089 I0.0 J0.197 G03 X0.0578 Y0.1395 Z0.0089 I-0.1395 J0.1395 G03 X-0.3353 Y0.0 Z0.0214 I-0.1677 J0.0 G01 G40 X0.1379 Y-0.0002 G00 G90 X0.875 Y-2.0 Z-0.522 G01 G91 G41 X-0.1401 Y0.0002 F2.8 G03 X0.3373 Y0.0 Z0.0214 I0.1687 J0.0 G03 X-0.0578 Y0.1395 Z0.0089 I-0.1973 J0.0 G03 X-0.1397 Y0.0579 Z0.0089 I-0.1397 J-0.1397 G03 X-0.1399 Y-0.058 Z0.0089 I0.0 J-0.1979 G03 X-0.0581 Y-0.1401 Z0.0089 I0.1401 J-0.1401 G03 X0.0581 Y-0.1403 Z0.0089 I0.1984 J0.0 G03 X0.1405 Y-0.0582 Z0.0089 I0.1405 J0.1405 G03 X0.1407 Y0.0583 Z0.0089 I0.0 J0.199 G03 X0.0584 Y0.1409 Z0.0089 I-0.1409 J0.1409 G03 X-0.3373 Y0.0 Z0.0214 I-0.1687 J0.0 G01 G40 X0.1379 Y-0.0002 G00 G90 X0.875 Y-2.0 Z0.5 M09 G28 G91 Z0.0 M19 G28 Y0.0 M30 % |
Thank you fellas for your reply's we are trying the suggestions now. My machine will not accept code with decimals. I hate it as well, but like mom used to say poor people have poor means. The alarm Codes I recieved are #11 (Arc Radius is zero in arc command) #15 (H number is programmed wrongly) I think that is fixed #50 ( Spiral Pitch is Zero in linear-circular) I hope this helps. |
| From what I can gather from the programming manual alarm #50 is because you don't have a K in each spiral block. It should be the spiral pitch amount, which I believe should be the same as the Z amount. Not sure why you're getting the alarm #11. N203G91 G01 Z-4989 F220 N204G41 X1523 Y-1523 F76 H21 N205G17 G03 X1523 Y1523 Z0089 I0 J1523 K0089 F30 N206G03 X-3045 Y3051 Z0179 I-3051 J0 K0179 F43 N207G03 X-3057 Y-3051 Z0179 I0 J-3057 K0179 |
#10
| -d % N1g40G28 X Y Z N2G90G92X309949 Y61959 Z0 N4G90G43G00 X8750 Y-20000 Z5000 H23 N5G01 F220 Z0 N6S2000M03 N7M8 N8G91 G01 Z-4989 F220 N9G41 X1523 Y-1523 F76 H21 N10G17 G03 X1523 Y1523 Z0089 I0 J1523 K0089 F30 N11G03 X-3045 Y3051 Z0179 I-3051 J0 K0179 F43 N12G03 X-3057 Y-3051 Z0179 I0 J-3057 K0179 N13G03 X3057 Y-3062 Z0179 I3062 J0 K0179 N14G03 X3068 Y3062 Z0179 I0 J3068 K0179 N15G03 X-1534 Y1534 Z0089 I-1534 J0 K0089 F30 N16G01 G40 X-1534 Y-1534 F220 N17G00 Z4097 N18G90 G00 Z5000 N19G92Z0 N20G28XY N21M9 N22M5 M30 % This is my code at this point. It starts moves down turns on spindle and begins arc move and throws this error. #51 ( End Points of straight line and arc are different in linear circular simultaneous three axis interpolation) I know we are getting close. |
#11
| I wanted to let everyone know that we have this issue solved and thank everyone that contributed. This is the code that finally worked. XYZ are the endpoint or the helix IJ are the centerpoint of the helix and K is the pitch of the spiral in one revolution. The real issue was the putting the G17 in each of the helix lines. Again thanks for taking the time and have a great day. % N1g40G28 X Y Z N2G90G92X309949 Y61959 Z0 N4G90G43G00 X8750 Y-20000 Z5000 H23 N5G01 F220 Z0 N6S2000M03 N7M8 N8G91 G01 Z-4989 F220 N9G41 X1523 Y-1523 F76 H21 N10G17 G03 X1523 Y1523 Z0089 I0 J1523 K0714 F30 N11G17 G03 X-3045 Y3051 Z0179 I-3051 J0 K0714 F43 N12G17 G03 X-3057 Y-3051 Z0179 I0 J-3057 K0714 N13G17 G03 X3057 Y-3062 Z0179 I3062 J0 K0714 N14G17 G03 X3068 Y3062 Z0179 I0 J3068 K0714 N15G17 G03 X-1534 Y1534 Z0089 I-1534 J0 K0714 F30 N16G01 G40 X-1534 Y-1534 F220 N17G00 Z4097 N18G90 G00 Z5000 N19G92Z0 N20G28XY N21M9 N22M5 M30 % |
| Newbie- post code trouble, or me? | Martin 007 | BobCad-Cam | 7 | 07-30-2008 01:52 AM |
| NPT Threadmilling | john_mccarron | GibbsCAM | 1 | 07-20-2007 05:54 PM |
| Threadmilling | MetalMolder | General Metalwork Discussion | 4 | 06-29-2007 03:41 AM |
| Trouble with DXF to G Code Transfer | mlapacz | SheetCam | 8 | 03-04-2007 12:25 AM |
| Trying to make this work- G code | WOODKNACK | TurboCNC | 17 | 06-10-2003 12:00 PM |
