| G-Code Programing Discuss G-code programing and problems here! |
| I ran it through MicroTech simulator and it ran ok. What block did it act up for you? Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
Can't manage to let it work better(can't even control feedrate), that's why I tried G00 becouse that's faster. I've written my own program to create this code from a picture, The picture you've included looks ok except for the strange lines... Thanks |
| It runs slow because you have the feed speed set to 300. Try G01 F5000 and it will move pretty quickly. Look at your code, those strange lines are in there, right at the beginning and end of the program. Good luck |
Thats the one G0 F300 The F300 doesn't do anything. The G0 says go as fast as it can go.. You should never be able to actually do work with a G0 command it is just for moving to a new location or returning home. G1 F300 means to move at a controlled speed. 300 inches per minute G1 F500 would be faster. Ect However if you have your program set up right the 300 means inches per minute if you are using inches. That is a very fast feed rate for most systems.. As you try to go faster you are much more likely to lose steps. Asuming this is a stepper based system. Again G0 is defined as Rapid Positioning Command ( no cutting) per the CNC Pro Documention.. Garry |
This is fixed and the system is perfectly running again! My settings are in metric, so 300 millimeter per minute. Not very fast but need this for engraving. |
#10
I'm new to cnc so I don't know all the codes yet. |
| Test cutting files. ( Webdings ) | ynneb | DIY-CNC Router Table Machines | 14 | 06-08-2004 02:32 AM |
| power supply test | dlenox | DIY-CNC Router Table Machines | 5 | 04-27-2004 09:06 PM |
| Test Relays | georgebarr | DIY-CNC Router Table Machines | 10 | 03-09-2004 03:34 AM |
