Results 1 to 9 of 9
Thread: URGENT.
    Jun 2009
    Zimbabwer
    URGENT.
    Hi all
    Am very new to CNC
    Programming a Supermax with Fanuc OT Control
    Trying to thread a Nut INTERNALLY
    tried using G76 but the Graphics Display shows it still cutting EXTERNAL thread
    WHY?????????????????????????/
    x91.6
    z1.0 M08
    G76 P011060 Q030
    G76 X91.6 Z-11.0 P4580 Q030 F1.5875 (16 TPI )
    WHY is this not working
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    On my machine, ID vs. OD is determined by the X position being smaller than the G76 X. And this X position also determines the pullout position at the end of each cutting pass so you have to choose this value carefully. In short, try changing your X91.6 to something smaller.
    Karl
    Registered dcoupar's Avatar
    Mar 2003
    x91.6 <--- must be less than major diameter - 2* height of thread
    z1.0 M08
    G76 P011060 Q030
    G76 X91.6 (major) Z-11.0 P4580 (height) Q030 F1.5875 (16 TPI )
    Also, your P value seems to be incorrect. Are you specifying 4.58mm (0.180) or 0.458mm (0.018)? Neither sounds right for 16 TPI)
    May 2007
    What is the thread size call out on the drawing?
    Registered maz43's Avatar
    May 2009
    Threads
    Your P value for a 16 tpi ID thread should be P3380.
    Your X start point should be smaller than your X value in the G76 line for an ID thread.
    Good luck.
    Mar 2003
    maz43: It appears as if he's programming in millimeters. I believe your P3380 is 0.0338 inches, correct?
    May 2007
    Appears it isn't too "URGENT" after all.
    Mr. Coupar, my Hardinge manual says the format for P and Q is Q4 P4 for inch and Q3 P3 for metric. We know this means P3380 is .3380 for inches. What I don't know is how the control handles an extra digit. Does in simply ignore the left most digit in P3380 making it .380 for metric? The machine manual doesn't say. The Fanuc operator's manual I looked at doesn't even mention the number of digits allowed in the address.
    What I can tell the original poster is that the machine appears to be threading an OD thread because his P-value is too large. Plus his start position accentuates the problem. We use to have a Hardinge Super Precision (now at a sister company). P3500 is .03500 with it, but when the program runs on a standard Hardinge it becomes .3500 and it acts like the OP is describing.
    Mar 2003
    g-codeguy: I believe P can have 8 digits. So P12345678 would be 1234.5678 inches, or 12345.678 millimeters. And I don't think it ignores any digits. The way I read it, P3380 is .3380 inches or 3.380 millimeters. But you're right that it doesn't appear to be URGENT anymore.
    May 2007
    Quote Originally Posted by dcoupar View Post
    You are most likely correct. That is why his ID thread appears to be an OD thread. .1803 inch is a bit much for thread height on a 16 pitch thread. The tool is going to drop down a fair amount to start its threading cycle. Especially since his approach and ending thread dimensions are the same. Wouldn't be quite so bad if the approach was where it should be.
    1. Need Help!- urgent help
      By traxxtito in forum WoodWorking
      Last Post: 04-19-2009, 01:19 PM
    2. urgent need !
      By y.y in forum Stepper Motors and Drives
      Last Post: 09-27-2008, 04:59 PM
    3. I need urgent help
      By Bezgin in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 09-28-2007, 09:49 PM
    4. Urgent Help Needed!
      By tmole in forum Bridgeport and Hardinge Mills
      Last Post: 02-23-2007, 08:04 AM
    5. URGENT: 2J Quill return sping replacement -URGENT
      By NC Cams in forum Bridgeport and Hardinge Mills
      Last Post: 02-13-2006, 11:48 PM
