Old 06-08-2009, 03:36 PM
endgrainguy is on a distinguished road
eliminate start and stop of spindle for short program?
I have a short program I would like to run over and over without having the spindle stop, to eliminate the ramp up wait, and save on energy costs by not constantly starting and stopping (it's about a 10 second program). How do i do this? I imagine I can maunually edit the mach3 code to do it, but haven't been successful. I've tried eliminating the M commands but can't get it to do what i want. Thanks!
Old 06-08-2009, 04:26 PM
iamstink2k is on a distinguished road
instead of a m30 at the end of the program use a m00 to stop and change part then a m99
should loop the prog without stopping spindle
Old 06-08-2009, 05:43 PM
ger21's Avatar
Just take the M codes out of your progam, and start the spindle before you start running parts. Stop it when you're done.
Old 06-08-2009, 05:45 PM
ger21's Avatar
Just noticed, in General Config, try unchecking the option to "Turn Off Spindle On M30".
Old 06-08-2009, 09:06 PM
spindle non-stop solutions
thanks for help. Solution 1 works pretty well, but necessitates 2 cycle start hits between cycles, and maunual changing of each program. #2 which I had tried and couldn't make work, I didn't try again. And Ger had the best advice of all, a simple easily reversed config change, which I had looked for and missed. Thanks, this forum is the best!(And I"m so happy that my machine now runs well enough I seldom need it!)
vfd spindle start/stop problem endgrainguy General Electronics Discussion 19 12-13-2010 10:49 PM
Need Help!- G-Code to start and Stop Spindle/Router planekrazie G-Code Programing 10 02-09-2009 08:54 AM
spindle start/stop through VFD endgrainguy General Electronics Discussion 5 01-09-2009 09:47 AM
Super X3 spindle start/stop from Mach3 jallitt Benchtop Machines 1 06-22-2008 08:23 AM
Stop/start a program jimglass TurboCNC 3 06-10-2003 08:59 AM
