Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: G Code Cheat Sheet?
    Jan 2005
    G Code Cheat Sheet?
    Does anyone have a "Cheat Sheet" for standard G Code formats? I think we all have the Fraction/Decimal/Metric/Tap charts hanging from our walls, but what about something like this example?
    Drill Chip Break
    G83 X(location) Y(location) Z(finish depth) R(start depth) Q(pecking depth) F(feed speed)
    The references I've found list each seperately with lots of uneeded text or assume you know what the parameters can be.
    CP
    Registered oldjohn's Avatar
    Feb 2005
    Sydney Australia
    Quote Originally Posted by cp8071
    Drill Chip Break
    CP
    Do you mean...
    Attached Files Attached Files
    www.joescnc.com joecnc2006's Avatar
    Aug 2004
    Registered HomeCNC's Avatar
    Mar 2003
    Quote Originally Posted by joe2000che
    I would say not quite. What cp is asking for is more than just the description of each g-code. he wants the usage format for each G and M code. I could see where that would be nice to have too. Maybe someone who knows the codes inside and out can make one for the zone users.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Registered ghyman's Avatar
    Feb 2005
    I'm on it... I've got a pretty good start on one, and should have it polished up for general consumption in a day or two, if that's alright w/ everyone?
    May 2003
    Heres a pretty good G&M Code EIA-274 reference by Dave of turbocnc, unashamedly copied from the Turbocnc Yahoo forum. Someone spent a lot of time making it into a pdf booklet print format. There's a txt version on the Files saction of the group too.
    Attached Thumbnails Attached Thumbnails G Code Cheat Sheet?-g_m_code_booklet.pdf
    Jan 2005
    HomeCNC: That's exactly what I'm looking for. "Usage Format for each G and M Code" is a great way to describe it! I took a look at that PDF and that's the closest thing I've seen so far.
    While we're talking about it. Does anyone know of a good description/tutorial of using G02/G03? Maybe a little calculator program which gives radius with start and end ... or gives end and radius based on start and angle? I'd like doing G-Code be hand sometimes and I never get these right the first (second or third) time!
    CP
    Feb 2005
    Sydney Australia
    G'day chip
    Try AutoEditNC from:
    http://www.betatechnical.com/autonc.htm
    There is a good built-in calculator for angles, trig, arcs, speed and feeds, etc. very usful for beginners.
    Oldjohn
    Feb 2005
    This is the "beautified" version of the list that I give to my shop; please note that there are both lathe and mill codes listed, as well as a few fanuc/fadal/citizen codes that may not be universal!
    Feb 2005
    Sydney Australia
    Well done mate
    Old john
    Oct 2006
    Quote Originally Posted by oldjohn View Post
    Do you mean...
    Thanks that was what I was looking for. Do you also have a chart for M codes? Thanks
    Feb 2005
    This ain't pretty, but it's the best I got.
  • Page 1 of 2 12 LastLast
    1. looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft
      By troyswood in forum Ability Systems - LPT Indexer and G-Code
      Last Post: 12-24-2006, 10:21 PM
    2. Having trouble cutting aluminum sheet
      By fastturbovet in forum General Metalwork Discussion
      Last Post: 06-14-2005, 11:33 PM
    3. parametric programming
      By Karl_T in forum CamSoft Products
      Last Post: 05-24-2005, 03:58 PM
    4. I need sample G code program
      By bunalmis in forum G-Code Programing
      Last Post: 08-24-2004, 04:50 AM
    5. Getting The Most Out of CNCzone's Posting Features
      By CNCadmin in forum CNCzone.com FAQ
      Last Post: 03-02-2003, 12:08 AM
