| G-Code Programing Discuss G-code programing and problems here! |
| Ok, I know that what I have here is not advanced enough to do this, so maybe you guys can help me figure out how to make this work. Our company runs an older fanuc controller and amada pega turret punch press. Our primary method of programming is an old DOS computer and New Dawn Systems part preview program, and they've been doing it this way for the better part of 10 years. I have 4 programs that orient a part in a direction that is very much less than ideal for metal usage, so I'd like to turn the part 90 degrees so that I can use the g73 mirror function to stagger parts on the sheet and get more yield from the metal. Unfortunately, it'd be quite a task to completely reprogram it, and I have no ideas as far as ways to rotate the program. Any help? Thanks, Jason |
| IF your control can support Coordinate rotate, it's a snap. Usually a G68 command. I imagine its the same on a punch. For machine centers it goes something like this: G68X0Y0R90. ... with XY being the point of rotation and the "R" for angle. "G69" cancels the rotation mode. This is an OPTION for FANUC controls. Some machine builders added it as a standard, others left it as an option.
__________________ It's just a part..... cutter still goes round and round.... |
| You're probably not confused... some MTBs or machine types will have some difference in code. Now, your G68 may still be functioning the same way for nibbling arc. But this could cause issues if you G68 within a G68... not sure on a Amada. What you need to look for is something along a "Coordinate Rotation" code in a programming book.
![]() Everything online says g68, and the book says nothing. Perhaps its just not supported.
__________________ Amada Pega 345 K, Fanuc 6M |
| I have a manual from an old Amada laser that may help. Try G65 P9050 X, Y, E, A, B, R. X = Center Y = Center E = Scaling Raito( 1= 1:1) A = Center X to rotate around B = Center Y to rotate around R = Rotating Angle Independent CNC Programmer http://www.independentcnc.com/ My mission is to share CNC programming innovations for a lifetime. |
| Please i need your help!!! i have an old AMADA VELA II Punch turret with the FANUC 3000C control, i dont know how do a program , i need the G and M codes for this kind of machine. I hope your cooperation. |
| Problem- rotate? | gromit68 | Alibre Design | 3 | 09-06-2008 02:07 PM |
| Rotate G68 | cadman@teluspla | Haas Mills | 8 | 05-08-2008 03:39 PM |
| Need Help!- My stepmotors don't rotate.... | Mikael | Controller & Computer Solutions | 1 | 04-22-2008 09:06 PM |
| rotate on axis A | tonyas | Mach Software (ArtSoft software) | 0 | 01-03-2008 04:20 AM |
| Rotate and copy | bdrmachine | Solidworks | 6 | 02-02-2007 09:56 PM |
