| G-Code Programing Discuss G-code programing and problems here! |
HI ALL, I HAVE OLD MORI MH-40 CONTROL MF-M5. I BELIEVE IT DOESN'T HAVE RIDGID TAPING SO I BOUGHT A TAPPING ADAPTER AND IT STILL DOESN'T WORK. WHAT IS THE RECOMMENDATION? WHAT IS THE TAPING CYCLE? THANKS ALOT! MORI |
| Most people use G84 for tapping. What kind of tapping adapter? What do you mean when you say "It still doesn't work"? What happens when you try to tap a hole? What does your program look like? This should be roughly what you need to program. N10 T10 M6 (1/2-13 TAP) G54 X0. Y0. S260 M03 G43 Z0.2 H10 M08 G84 Z-1.0 R0.2 F20. X1.0 X2.0 G80 M09 G91 G28 Z0 G91 G28 Y0 M30 |
| Also remember that milling machines tend to be programmed in feed / min. **change the RPM and the feedrate also has to be altered**** If you program in feed / rev *** changing RPM has no effect on pitch*** If you want to program in feed / rev ( pitch ) a g-code must be stated on or before the tapping cycle. If using a tapping head that allows extension and compression, use approx 95% feedrate factor, ie 1/2 UNC tap G95 G84 G99 X--- Y--- Z-1.5 R.2 F0.0769 (100%) G84 G99 X--- Y--- Z-1.5 R.2 F0.0730 (95%) X--- Y--- G80 G94 |
| Your controller might also need to read an "M29" code to initiate rigid tap mode? ( TAP 5/8"-11-4 HOLES ON 5.5" B.C 1" DEEP.) G00G40G80G90 G80T16M06 G00 G54 X1.9446Y-1.9446 S0130 M03 G43 Z4 H16 M29 S0130 G98 G84 X1.9446 Y-1.9446 Z-1 R.4 F11.82 X-1.9446 Y1.9446 X1.9446 |
Here's a program that might help...... T8 M06; G90 G54 G00 X0 Y0 S754 M42; G43 H08 Z.5 M8; G84 G99 Z-1. R.5 F58.; G80 G00 Z1. M9; G28 G91 Z0 Y0 M5; M30; HERES SIMPLE FORMULA TO FOR CALCULATING THREADS PER INCH, 1 DIVIDED BY 13(this number is the thread pitch) = ??? Take ??? X RPM(ei. S754) = F58. (is the feed ) Suggestion; Might want to make sure you drill the hole with the drill which call for the tap size. Use the right kind of tap (I prefer EXO tap spirral flute black oxide, a little expensive but u can really tap at pretty high speed with this and this tap pulls out the chip instead of being clogged inside the hole which in most cases can break taps, with this sample pro gram ucan use standard tap holder, try not to use holder with collet for tap cuz the tap can spin in the holder that cross thread and also break.) |
| Something I always like to do when tapping is to pick speeds and feeds that do not have any rounding (or decimal smaller than X.1). IE 13 tpi I would use a RPM that can be divided evenly by 13 13 RPM = 13 threads = 1 inch per minute. So: 130 RPM = 10 IPM feed ect. Just pick you speed and feed range and find the closest speed that results in even numbers. A decimal for a feed is fine as long as you are sure your control uses all the digits and there is not any rounding when you calculated it. |
| G84 & G74 tapping cycle | Karl_T | G-Code Programing | 8 | 12-01-2008 07:52 AM |
| Newbie- G84 CANNED TAPPING CYCLE | mmussack | Mastercam | 15 | 11-25-2008 10:02 AM |
| Coolant M7/M8, Tapping Cycle 207 | cutteredge | General Metal Working Machines | 0 | 01-09-2008 04:12 PM |
| peck tapping cycle | jdsmith0524 | General Metal Working Machines | 9 | 12-16-2006 10:36 PM |
| Correct tapping cycle??? | Karl | G-Code Programing | 5 | 05-31-2004 04:37 PM |
