Old 04-27-2009, 03:21 PM
traxxtito is on a distinguished road
machine home
hi all
i have a problem in machine home point ,
when i press home push button while machine is stop in any point , machime didn't go to home point correctly in X axis and Y axis... just move short distance in this axis and stop and machine coordinate became X0 Y0 Z0 .
but this place not the spicific place for home point .
you know the most of CNC machine , home point in the left bottom machine work ... now machine define the point it already stop in there as machine home point .
this happend when i press home push button in this position .
pls. advise
Old 04-30-2009, 05:32 PM
Ghallow is on a distinguished road
Your ruler or lineaal, it's an magnetic strip by which the machine defines where it's actual position is,(x,y,z axis) maybe a little dirty.
The machine, sometimes, can give some strange side effects like running over referencepoint or will give a referencepoint reached while it has not.
Just clean it up & it will work again like before.
If your machine has heidenhain onboard you can try this (keep the feedrate to < 5%, crashes are possible on a dirty ruler) ;
M30
X0 Y0 Z0 m92
M30
Old 04-30-2009, 05:38 PM
hi
r u meaning sensor ?
what do you mean of ( lineaal ) ?
Old 05-01-2009, 06:01 AM
Lineaal is the part called in Dutch, i don't know the English word for it,
I translated it with an online dictionary where it was translated to ruler in English if this was an correct translation i don't know.
It could also be the sensor attachted to this ruler.
Old 05-02-2009, 07:36 PM
Superman's Avatar
Superman is on a distinguished road
I think he is refering to the linear "scales" on each axis
Old 05-03-2009, 02:38 AM
no no no
sorry but thats not the problem.... i forget to tell you machine is working good ... but just no move in X axis when i press home boutton ... but X axis moving in jog mode and automatic mode good .
i think may be it hardware problem ... what's your opinion ?
Old 05-03-2009, 12:22 PM
dcoupar's Avatar
What machine? What control?
Home Made Injection Machine Rob_M. Moldmaking 86 12-06-2011 10:17 PM
Home Built Edm Machine sanjiv EDM Machines 132 08-07-2011 05:47 AM
Need Help!- machine home problem traxxtito Machine Problems, Solutions , Wireless DNC, serial port 0 04-27-2009 03:15 PM
If you have a 300 or more pound machine can you tell me how you brought it home? slashmaster General Metal Working Machines 13 03-23-2009 06:02 AM
Please Recommend a Home welding machine ThomasAlva Welding, Brazing, Soldering, Sealing 8 08-23-2007 01:34 AM
