| G-Code Programing Discuss G-code programing and problems here! |
I need someone's help with 2 simple gcodes. I have just finished my 1st machine and want to mill 2 words in wood. I am just starting to learn cad and cam, however I want to show someone something milled from the machine now. I need gcode for the words "Phil" and "Ascott" Simply plunge into wood surface 1/8 in and mill out the letters. Size of letters aprox 2 in. and in any font or style. Any help would be appreciated, as I feel it will take me too long to learn how to do this and I need to show a sample a.s.a.p. Thanks in advance Chas |
| This is what I would use for some fast g-code from text. And it's free... http://www.deskam.com/deskengrave.html |
| do you want machine the letters along the vector ( good for a Vee bit ) Machine the letter via area clearance , the leters are engraved into your work piece as a flat area. ( Good for a square bit ) Or machine the rest of the material and leave the letters still on the piece. Or you just dont care......you want movement |
| The easiest way is for you to get a program such a 'DeskEngrave' , simple and easy to use, and the price is right.. attached is a file crested with program, font size is 36, depth is 0.125, and can be easily sized with most CNC output program , a good one to start with might be KCam [Kellyware], older versions unsupported, but free, enjoy |
| Pythagoras Thankyou so much for your help, The last suggestion would be excellent. Even more that I could have hoped for. The total size of the example perhaps 3 x 6 in with the word "Phil" exposed and background milled away. Same for "Ascott". But anything you could come up with would be great. You are helping me out big time. If I can return the favor I would be more than willing. Chas WayneHill - I tried DeskEngrave - not sure what I did wrong entered the word and asked it to create gcode. what it did was create gcode for 3 boxes no letters. As I said I want to learn all this, however I need to show a result from the machine. Thanks for the thought. Over the next few months I plan to learn enough cad/cam to make a mess. (hahaha) |
| DeskEngrave will machine the letters [pattern] OUT of your stock, not the other way around.. You will need something a little more powerful [and complex] to do inverse relief..the proper name you are looking for is profile and pocket machining.. enjoy.. |
| I hope this is alright. I had lots of troubles adjusting to imperial measurements. The z zero is at the top of your work piece. You will be routing 5 mm deep You will need a 1/8 flat bottomed bit for this I suggest doing an air cut b4 running this code on timber. Last edited by Pythagoras; 01-19-2005 at 06:55 AM. |
#10
| Thankyou Pythagoras and vladdy!! I will take a look at them on the weekend, I have to fly out of town for 2 days, last minute meeting came up. But when I get back it will be the 1st thing I do. Thanks again, I will let you know how I made out. Chas |
#12
| Thanks again guys, Pythagoras I tried your gcode, however the settings you have for z are out of the range of my machine, I plan to play with the code on the weekend. Vladdy I just modified your z range to work with my machine and split it into 2 words and actually milled them!!! Thanks!! Great to see my machine work!! Now I will have something show for it all. (haha) Pythagoras I am going to get your code working this weekend and that will be the example that I hope to show, it looks impressive!! Once again, thanks guys for all your help. Perhaps soon I will know enough about gcode to help someone in the future. And Zoff perhaps you didn't read my 1st post, I am new to this and am still learing gcode, cad and cam. |
| Autocad to gcode | JamesMI | Autodesk Software (Autocad, Inventor etc) | 17 | 12-02-2011 03:54 AM |
| Is it possible to get a gcode into Rhino | MrBean | Rhino 3D | 11 | 04-03-2005 08:41 AM |
| gcode to gcode converter | july_favre | General CAM Discussion | 4 | 05-24-2004 07:51 PM |
| dxf to gcode problem... | freezer | General CAM Discussion | 9 | 02-19-2004 01:02 AM |
| Gcode verify autocad plugin | balsaman | General CAM Discussion | 1 | 10-31-2003 12:22 PM |
