| G-Code Programing Discuss G-code programing and problems here! |
| Don't know about TurboCNC, but.... G03 is a counter-clockwise arc, G02 is clockwise. If you dont program an X or Y with G02/3 you might get a full circle, but you would have to program an I and/or J as circle center G03I-1.0 should get you a ccw circle, 2mm in diameter (I'm assuming metric, as you're in Sweden The -1.0 means the circle center is 1.0mm from the start point, in a negative direction. Hope it helps! |
| The general syntax for a clockwise arc is G02 X Y I J The I & J parameters indicate the center (I for X, J for Y) of the arc. They are relative to the current machine position. For example, to interpolate a 5" diameter circle centered at (10,10) G90 ( absolute positioning) G01 X10.0 Y12.5 (move to start of arc) G02 X10.0 Y12.5 I0.0 J-2.5 (arc center is relative, not absolute)
__________________ Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers |
| cut circle | bbrown2005 | Mach Wizards, Macros, & Addons | 2 | 02-04-2009 06:41 PM |
| Problem- circle | AngelT | Mach Mill | 1 | 06-30-2008 08:59 AM |
| Circle problem | Captain Midnigh | Milltronics | 3 | 11-09-2006 02:11 PM |
| I have a problem with my gcode or my conversion to gcode , everything is tiny? | NickLatech | G-Code Programing | 0 | 03-10-2005 12:46 PM |
| gcode to gcode converter | july_favre | General CAM Discussion | 4 | 05-24-2004 06:51 PM |
