Old 04-13-2009, 01:23 PM
slkret is on a distinguished road
Rookie g41 problem simple part
Hi:
I'm a g code rookie. I am trying to cut a hand for a wood gear clock. It basically looks like an arrow. There are a number of g3 moves that look fine until I turn on cutter compensation with a g41 call. On the final g3 move, the Mach3 simulation shows the cutter path not ending where I think it should (line 95). The matching arc created in line 55 looks fine in the simulation. I have not done a dry run on my router yet but I'm wondering if I've misses some obvious thing with g3 or g41 or is this just a graphics glitch in Mach3?
I've tried to use the R.75 word instead of the I-J on this line and I get the same result.
Here's the code:
N5 g90.1
N10 M6 T3
N15 g0 x0 y0
N20 g1 z-.78
N25 g0 z0
N30 g0 x9.1265 y.099
N35 G42
N40 g1 z-.78 F10
N45 g1 x9.1265 y-.0537
N50 g1 x6.7628 y.7115
N55 g3 x6.2738 y.1875 I7 J0
N60 G1 X.4635 Y.1875
N65 G3 X-.4635 Y.1875 I0 J0
N70 G1 X-3.0738 Y.1875
N75 G3 X-3.0738 Y-.1875 I-3.8 J0
N80 G1 X-.4635 Y-.1875
N85 G3 X.4635 Y-.1875 I0 J0
N90 G1 X6.2738 Y-.1875
N95 G3 X6.7628 Y-.7115 I7 J0
N100 G1 X9.1265 Y.099
N105 G1 X9.1265 Y -.0537
N110 G40
N115 G0 Y0
N120 G0 X0 Y0
N125 g91.1
Some help would be greatly appreciated.
Steve
Old 04-30-2009, 04:51 PM
Ghallow is on a distinguished road
Hello,
I'm missing some things here.
I will give you an example;
0000 (programname)
;the workpiece offset = laying in the left uppercorner
;workpiece length= 130 widht=90
n10 g17 g40 g80 g90
n20 m6 t1
n30 s1500 (spindlespeed) m13 (Spindleturn to the right & cooling on)
n40 g54 (workpiece zeropointoffset)
n50 g0 x0 y-10
n60 G43 (call tooloffset) z2 (safetydistance above workpiece) h1 (call up toollength from toolmagazine)
n70 g01 z-10 f200 (feedrate frees)
n80 y90
n90 x130
n100 y0
n110 x-10
n120 g41 x15 y25 d11 (radiuscompensation frees)
n130 y65
n140 g02 x25 y75 r10 (radius curve)
n150 g01 x105
n160 g02 x25 y75 r10 (radius curve)
n170 y25
n180 g02 x115 y65 r10 (radius curve)
n190 g01 x25
n200 g02 x15 y25 r10 (radius curve)
n210 G01 y35
n220 G40 X-10
n230 z100
n240 m30 (end off program rewind)
Old 05-02-2009, 07:31 PM
Superman's Avatar
Superman is on a distinguished road
n170 y25
Alter to n170 G1 y25
you need to tell the machine to change from arc to line back to arc.
To fault find in a program and you are not sure where the error is, use single block, the error has to be from the current block being executed to the control's read ahead buffer setting ( usually 4 to 9 lines )
Old 05-03-2009, 12:21 AM
ger21's Avatar
Originally Posted by slkret View Post
Hi:
What version of Mach3 are you using? There are some comp bugs in Mach3. Version 3.43 fixes them, but may have some other problems. Your code looks fine in 3.43.
Old 05-31-2009, 12:01 AM
xEstrnDrgnx is on a distinguished road
you forgot to turn the cutter comp. on
block should be g42 x9.125 y-.0537 D3(D3 is ur tool offets this should be included
on the cutter comp. block always just make sure
the tool diameter matches the diameter
entered on ur tool offset table, for instance If
T3 is .500 then the offset should read .500, just
keep in mind if the offset diameter is less than
the diameter of the tool then the tool will cut
more if it is more than the tool diameter then it
will cut less, this is how u can fine tune ur cut
with cutter comp on G41 or G42 especially
when tool wears.)
Old 05-31-2009, 01:41 AM
Superman's Avatar
when tool wears.)
Which post are you amswering ?
#1 or #2 ---- both are pretty old
Plus, it is good manners to reply, if your problem is solved or still unresolved.
Need Help!- HELP ANY ONE HAVE A PART SOMETHING SIMPLE bobrob General Metalwork Discussion 1 03-26-2009 11:22 AM
Need A Quote- Need a simple part made beerdrinker301 Employment Opportunity 9 02-04-2009 03:04 PM
Please Help!! Simple 3-D part not so simple for me eaglegage Mastercam 16 05-15-2008 10:00 AM
simple part program chevblue2 G-Code Programing 3 02-10-2008 03:20 PM
RFQ on simple part... nate Employment Opportunity 14 04-28-2006 01:25 AM
