| G-Code Programing Discuss G-code programing and problems here! |
I have a Practical CNC with a WinCNC controller. I use BobCad for creating g-code files. I am adding a Peck Drill Cycle to my machining tools. Simple questions; 1. Do I have to have G83 on each line of code? 2. How do I set the Rapid movement Z in the code? Thanks Sam |
| Hi Sam, G83 is a canned cycle designed to make it easier to drill multiple holes. While I don't have either of the mentioned programs, here is how it works on Mach3 and Deskcnc. 1. No. the code looks like this, G83 x0 y0 z-1 r.1 q .050 x1 y1 x0 y2 x4 y4 G00 z2 (to clear the tool and cancel the G81) X0 Y0 The second line and the rest just have x and y coordinates. The tool does the following. It will rapid to the X0 Y0 Z.1 position, then it will drill in increments of .050 (the Q value) retracting to .1 above the surface (the R value) until it gets to -1(the Z value). All of the retracts and the return to drilling are done at the machines rapid speed. The cycle stops the return rapid just short of the last depth, then goes to the feed rate to drill the next increment. It makes coding this much easier than hand coding it. It is also cool to watch. Be careful about setting R to 0 as it will rapid right to the surface of the part, depending on where your Z0 is set. IIRC You may have to add code to clear obstacles, so in my example above you might put in a G00 Z4, then on the next line a X0 Y0 to get around something and put the tool above the hole before starting the g83. It will then move to all the other X,Y values untill the G83 is cancelled by another G-code such as G00. You can even have just the X value or the Y value on a line and it is still valid. I would try some air cutting the first time to make sure it will work with your program and that I have not left out anything. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| A very important step is your first Z move before your G83 line entering into canned cycle mode. This sets and will be your initial plane. If your first move before the G83 line is G0Z3. This is the distance that the tool will retract above the part before moving to the next X,Y location. This can be specified by using a G98 in the G83 line of code. Most machines by default use G98. However if the 3” clearance from hole to hole is not needed then you can put a G99 which will use the R value as your clearance plane from hole to hole. In TotallyRC’s example it would be .1” Stevo |
| Hi sam A Stevo1 has the best & correct way to do it you also need to cancel with a G80 at the end of the canned cycle G90G17 S2850M3 G43Z2.H1 G83G98X0Y0Z-.250R.1Q.030F12 G80G0Z2. M9 M5 M30 As Stevo1 has said if your tool is clear of the part & you don't have to clear anything then you can use a G99 were the G98 is This piece of Gcode is just a small sample of what you need to do for a canned cycle the beginning of the Gcode sample is not complete
__________________ Mactec54 |
| I have a peck drilling problem (G83) while operating my Cincinnati Milacron Sabre 750 with 2100 Acrimatic controller; Below are the lines of codes I ran on the VMC, the G83 code went rapid to the clearance plane, then stopped there. It did not go further to drill the programmed hole. :100 T15 M6; HSS-Cobalt I (0.272inch diameter drill, 135o point angle) N10: G0 z1.0 M08 N20: G83 X3 Y0.3189 R0Z-1.6563 K0.125 J11 F0.7 S350 M03 W1 Please any help regarding this will be appreciated. |
What value do you have for the Gauge Height Parameter? Regards, Bill |
| if you will post this in the bobcad forum,under bobcad-cam, i will help you along with others, i use wincnc everyday, your post may need some adjusting and will need to know how your router is setup DW |
| I just tried it exactly the way you suggested and I still experienced the same problem. My Gauge Height Parameter I used a 6 inches aluminum block to set the surface length offset using TRAM, that was basically my reference point (ie 6 inches) before I then used a drill bit to set the Tool Length Offset from the 6" reference position. All codes worked perfect apart from the G83 'peck drilling' code....please any further suggestion or help will surely be appreciated |
#10
Has the G83 cycle ever worked? Does the G82 cycle work? Regards, Bill |
#11
The G83 has always worked and G82 works very well...That's why I know what what could be wrong with the code or if there's anything extra I should do that I haven't done. |
| Need Help!- Peck Drill cycle generated by post?? | nelZ | BobCad-Cam | 7 | 12-11-2008 10:09 PM |
| G99/G98 in peck drilling cycle | inflateable | EdgeCam | 4 | 10-24-2008 07:21 AM |
| To Peck drill or not to peck dril..... | Crashmaster | General Metalwork Discussion | 20 | 08-23-2008 11:33 AM |
| peck tapping cycle | jdsmith0524 | General Metal Working Machines | 9 | 12-16-2006 10:36 PM |
| G83 peck Drill cycle | Vaughan | G-Code Programing | 24 | 03-19-2004 11:11 AM |
